Bronco Raptor Factory Tire Size?
FellowM3
Northern NJ
Current: 22' Braptor, 2020 BMW M340
What size tire does the braptor come with?
I know press release said 37x12.5 on 17s, but trying to see how it comes compared to the SAS.
SAS is 315/70/R17.
Is the Braptor 315/80/R17?
FellowM3
FellowM3
Northern NJ
My tire size calculator only uses the tradition mm
how do these compare in height and width exactly to the sasquatches 315/70/r17?
Spooled
Republic of Texas
Sas Goodyears are 34.4" diameter and measure 12.7" width on a 9.5" wide wheel.
Raptor KO2's are 36.5" diameter and measure 12.5" width on a 10" wide wheel
FellowM3
FellowM3
Northern NJ
How’s you get the 36.5” diameter ?
my confusion is if it’s a 315/80 or a true 37x12.5
I’ve just never seen a tire in inches (like 37x12.5 lol)
Spooled
Republic of Texas
Those are the specs per BFG's website. It is a 37x12.50x17. Tire sizes listed by inches is common for large tires.
Ford Bronco Bronco Raptor Factory  Tire Size? Screenshot 2022-04-19 113546
monsterfd
2014 raptor widebody 37s, 2018 raptor 2018 JKU 35s
315/80 = A/B
1 inch is 25 mm
to convert width take 315 divide by 25 = 12.6
to get sidewall, B is a % of A, so 315 * .8 =252mm. this is total side wall (above and below the rim), youll need to divide that by 2 if you're only measuring the side wall radius which is 126mm, or 5"
