Deleted member 18651
Guest
That won’t happen. The programming is hard coded into the IPC (cluster)Same. Need @D2dhanover to figure out how to make it work with Forscan.
Raptor uses an entirely different IPC.
It will notthere are 3 wheels options on the GEN3 Raptor:
- base
- beadlock
- 37" performance package beadlock >> see below
It is interesting that all warthogs have always used Raptor wheels. I wonder when released, the warthog will be on the F150 bolt pattern?
@D2dhanover can you shed some light?
Those are up there as some of the nicest OEM wheels I've ever seen.there are 3 wheels options on the GEN3 Raptor:
- base
- beadlock
Yup. 100%And there is the "upgraded dash" that was supposed to be on OBX and up.
We finished testing on those a year agoBut people will spend and will pay whatever the price is on ADM oh yes folks will pay . The plastic dash means nothing what’s important is being the first few to have a Bronco Raptor .
PS: why no painted top if this supposed to be a MY23 , tops should of been out in the wild be tested.
I tried to find a photo at a similar angle, but the best I could find was an old spy photo. But, aside from the gauges, I do notice there is no overhang over the screen/on the top of the dash (I included another photo to better show the overhang.whats different on the dash that stands out so much? i dont see it!
do you mean the Tach?
Who did you have do that change?You should be able to retrofit the Digital dash to a lower Trim Bronco. It just depends on what all is needed to make the swap work. I swapped the digital cluster from the 18+ mustang into my 2016, but it required new steering wheel buttons, and new SCCM /clock spring Module, IPC Bezel and a lot of programing with forscan. All said and done it was about $2k to do the swap.
Younger buyer here and I couldn’t agree more. On the Hybrid RAV4 my SO and I are getting? Sure who cares. Yes I know shifting by feel is a thing but the bar graph tach is garbage.A sweeping tachometer needle is soooo much easier to read with a just glance as opposed to a digital vertical bar graph.
Now if you'll excuse me.
"HEY YOU KIDS GET OFF MY LAWN!"
