Engineeredthisway24
Matthew
Huntsville, Alabama
2008 Porsche Cayman S
Also appears to be space for 3 lights above the F O R D letters.
Most likely a DOT requirement due to the width just like the Raptor.
BradtheWelder
Brad
Moline, IL
1969 Ford Bronco
I believe this just a easily be a Ford Performance part too to give people their own personal look to their Bronco possibly.
_jeff
Central California
www.instagram.com
22 Bronco Badlands, 23 Lightning Pro, 14 FLD
I think it will look damn good just like it does on the Raptor, but...
BD grille is still my preferred.
Bellebracht
Missouri
‘18 Ford Focus RS, 2 door first edition
Isn't it the grille on the Base and Black Diamond?
edit: So the BD grille looks to be the one on the render, but 8200D has 6 slots top and bottom instead of 7. 🤔
Maybe it's what the WT was going to get before they put a Badlands one on it?
Mine has 6 as well…I did my render before these were released. It’s the heritage grill makes sense. Same amount of slots on the OG bronco 6 across ;)
Bellebracht
Missouri
Looks like @flip stumbled onto the Raptor / Warthog grill -- see grille "8200E"
You can tell by looking at the pic, that above the Ford and below the Ford will be filled in by the yellowish green plastic part behind it in the schematic. Looks like two rows on top and two on bottom, with a tiny 3rd row on the bottom where the opening expands to meet the headlight. Unfortunately it’s a low resolution image. But it looks 11-12 oval openings makes sense.some every other oval shaped opening looks to be pushed back a bit. I was hoping that would go with the hexagon shape you normally see on a raptor, but I’m guessing since all bronco grills have that oval shape, they are trying to stick with a similar design language…I’m mocking up a model of the grill now ;)
Bellebracht
Missouri
As far as the one above potentially being the heritage grill it’s easy to comfirm by looking at the camo heritage bronco already on this forum. You can see enough of the grill behind the camo to see the shape of the oval openings along with the hint of the red Ford letters.
Designkid
Designkid
Kris
New Jersey
2021 Bronco Badlands
Interesting because I was thinking it was a hexagon pattern. I know it's super low res but just above the "D" there is a good sense of a hex shape. The rest is just a blurry mess
JTBros
Long Island, New York
GR Corolla
Could this Warthog be electric or hybrid?
I doubt we'll see an electric Bronco until maybe 2024 due to the number of products they just launched. Incorporating a hybrid drivetrain like they put in the Aviator? Definite possibility.
Spooled
Republic of Texas
Not yet. It'll be the 3.0 like the Explorer ST. It'll be a couple years before we see a hybrid. There was a 2.3 hybrid powertrain leaked for the next gen ranger that I imagine will also make it's way into the Bronco.
Bellebracht
Missouri
I see what you mean. Would look a lot better with the hex if they stick with it
Thurmy7
Kevin
Fullerton, California
Suburban, Tacoma, Patriot
Seems odd that it would say FORD instead of BRONCO... but I like the larger FORD better either way.
