I have been watching the off road adventures of the new Bronco at Mo ab and the
Rubicon. What concerns me is that all the units testing have extensive roll cages apparently reinforcing the factory roll bar. This is disconcerting to me as I assumed
Ford would along with all the other upgrades install a roll bar that works. I would like to hear from Ford engineering as to the exact strength of the factory bar, and if it can't do the job than will there be an option for a replacement system that will??
ANY THOUGHTS???
UPDATE: I hate to say I am right but notice the B and C pillar Reinforcements on the New Bronco Raptor. I guess I just heard from Ford Engineering.
Also the 8.5" Track width increase speaks volumes.
The roll center had to brought down by a huge number. That effectively did it.
Looks like F-150 Raptor Hub frames and lower control arms, with same truck control arms, axles, sway bar, and upper control arm.
I love off the shelf parts I can use to upgrade my 2dr. Those front and rear axle assembles should bolt right on also. Don't think the increase in travel is necessary so shock towers and FOX super $$$ shocks are not in the works.
The sheet metal on the Raptor I am confident can be swaped out quick and easy just like a normal Bronco. Although the pressure vents in my book aren't necessary in a Vehicle with
almost 20" of ground clearance.
When I finally get my 2021 2dr sas which was built 12/17 I will do the math.
ANY THOUGHTS???
