Bronco Spacer Lift by Fordrangerlifts
North7
North Texas
SUV
Seems like all promises with no data. Where is their test and fitment specs to prove this works on all trims, without binding, bad cv joint angles, rubbing, etc.?
This is for the front, what about the rear?
The Bronco is at most 1/2" off level, why would they make it a 2 1/2, Front only, level?
Something does not smell right, photoshop engineering at its finest.
MaverickMan
Shane
Thats great and all but a front only spacer kit for $300 is kind of a rip off. I mean any half decent fabricator could make this for the front and rear for $150 in metal max. I planned all along making a 1.5" spacer for myself to put 36"s on either Badlands or Squatch what ever I get. I do own a drill press and a welder lol. I would also like to do a 1" body lift. Hate all you want but I want the clearance between the body and frame so I can keep the salt/mud/sand mix out of there. That and a spacer lift should fit me as big of tires as my wife can climb into it with. Keep all the factory bits. I have always wanted a vehicle all stock to just fabricate stuff for to maximize its stock potential. Always thought it would be a Fox body but a Bronco it shall be.
JCAntimatter
JCAntimatter
Long Island, NY
19 4Runner TRD PRO, Acura MDX
You're right.
Gr8Hortoni
Whitehall, Michigan
That seems like a lot of tire just from a spacer lift. I know on the Jeeps the “leveling kits” would give you the clearance for 35’s, but nothing more than that.
As far as it being for just the front, Jeeps are the same way for the most part. You don’t have the turning components to limit tire size like you do in the front. Rears will clear 35” in stock form.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
No. Just no.
Erock
US
2018 F150 Alpine edition
Not gonna get into the should/shouldn’t or will/won’t ... any of that jazz. Only came to say this... DAMN, what some ugly welds. 🤣
604Bronco
British Columbia
www.bronco6g.com
Felix808
SRV CA
And no pictures of the actual product. :unsure: I can wait a while. ;)
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
Spacers are stupid. The proper way will be replacement coil overs starting around $900.
