Hello everyone,
Ordering my Bronco, I almost reserved Outerbanks, I was looking at each trim specs on Ford's website VS Bronco Lineup PDF comparing models, I noticed that Base and Big bend on the PDF has the standard package as a standard option which includes:-
" LED headlamps; black door handles, mirror caps, fender flares and fender tie-down hooks; manual air-conditioning; and push button start " no mention for Ford Co-Pilot 360 Technology or a reverse camera
https://www.ford.com/cmslibs/conten...crossovers/bronco/pdf/21_Bronco_lineup_HR.pdf
If you go to the base and big bend trims pages-
https://www.ford.com/suvs/bronco/2021/models/bronco-base/
https://www.ford.com/suvs/bronco/2021/models/bronco-big-bend/
Under the packages tab, you see Ford Co-Pilot360™ Technology standard on both base and big bend and then again optional in big bend
Under the Safety-Security tab, you see also Ford Co-Pilot360 standard along with the camera ( big bend )
Under the interior features ( bid bend ), I see Blis and lane-keeping system as optional which is supposed to be part of the Co-Pilot360
Also base comes with equipment group 100A and bid bend comes with 220A which I don't see it mentioned anywhere on the PDF
I would happily pick big bend and save the difference over Outerbanks if Co-Pilot 360 is standard
for reference On the Bronco Sport base the Ford Co-Pilot360 includes
Pre-Collision Assist with Automatic Emergency Braking
Lane-Keeping System
BLIS® with Cross-Traffic Alert
Electronic Traction control
SOS Post-Crash Alert System™
Auto High-Beam Headlamps
Rear View Camera
AdvanceTrac® with RSC® (Roll Stability Control™)
So I am a bit confused here why on the PDF it shows the standard package which has no mention of Co-Pilot360 and rear camera like the Mid package, If I am mistaken or misinformed please correct me, move the post to the proper department if this is not where it should be.
Regards,
Lane-Keeping System
Rear View Camera
Regards,
