Grooticus
Attleboro
GMC
Challenge accepted?
I wonder what it would look like off center...
I’m just going to put it through the holes the brush guard mounts through. MA plates are malleable enough to make that work. I just don’t want those holes punched through F’s intended holes
Efthreeoh
Hummer H3T
Easy Fix (not to scale):
1 License Plate
2 Zip Ties
1 Cordless Drill with bit
15 Minutes
Or this, if you have OCD, or your state requires a center-mounted plate:
My plan is to use the three center Bronco bolts below the radar cutout. I have some black steel pallet shipping ribbon that I'll mount to the three center bolts then make some black nylon screw standoffs to mount the plate to the steel ribbon. It'll look clean and neat. A few runs through the brush and the plate will bend back towards the bash plate...
Broncoak
Aaron
Eagle River, AK
1996 FSB
Sounds good and not as lazy as my solution ?
carrellslake
Oregon
2022 Ford Bronco
Do you think the front recovery points are removable? The best spot in my opinion would be in front of one of them, using the two Bronco bolts above each one on the bumper. The problem is that the recovery point sticks out further than the bumper. I won't be using a winch or brush guard so they won't interfere with this plan. Odds are the aftermarket will come up with a good bracket mounted on the bumper somewhere but I'm hoping for a Day 1 solution.
kje22kje
Keith
St. Charles, MO
2017 4Runner TRD Off Rd
It was pointed out in another thread that the front hoop is probably shaped and located where it is (over the BRONCO on the grill) to provide room for the front plate.
Honestly, it might look okay paired together.
The old "two wrongs DO make a right" theory? I'm not sure. Aftermarket, you're our only hope.
Ford Bronco Bronco spotted with possible front license plate placement (pics) Plate
cmb
Chad
Appleton WI
2018 JL Rubi, 2020 Toyota Tacoma
Now add the winch option to that.
tshaw2009
Tony
Lebanon, MO
2011 F150 Lariat, 2018 Ford Edge Titanium
In all reality, this would be my preferred tie in location on the mod bumper
Well if those two Torx screws are the correct distance apart, that will be where my plate goes and that dumb bracket on the center of the grille will come off immediately. I'm bringing my drill for delivery.
mC.242
2021 Big Bend 4dr (sold)
Yuck. I see some creative modifications to make it less horrible in my future.
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
Uh oh. License plate frame seen again on Bronco going the other direction at one minute mark in video here:
Efthreeoh
Hummer H3T
Based on an earlier pic on this thread, the distance between the 3 bolts is around 5.5". The bolt holes for a license plate are 7" apart. If you want to drill holes in the license plate you could mount it directly to bumper using those bolts. Making an offset bracket using those bolts would be easy enough. I'm sure the aftermarket will sell something for $20 that could be fabbed in 20 minutes for $3 of materials (stainless steel bolts mostly).
