FATHORSE
Stephen
okc
nissan
I should of known better to start this on a work week. Problem I'm having is finding a good ground point to the rear driver back seat. Most people ground to the seat bolts, but the way they are elevated, I cant get a good solid ground. Tonight i will try pulling the back left panel out and see if there is a grounding point on either side. 2 doors don't seem to have any kind of soft top grounding point like in the PP5 video. So might have to use my imagination.
Compta38
Alabama
Ford Fusion
the quality of the sound is night and day different to me. Instead of being muddled, flat, and sounding like it’s coming out of a cardboard tube it’s extremely clear with solid and strong tones. I am honestly blown away it made that much difference.
Your description is exactly what I used when I test drove a WT with standard sound over the summer. I'm glad to see just adding the front speakers was such a difference and will be replacing at least the fronts and rears. I've read the kick panel speakers aren't really a huge difference but will wait for general consensus before writing those off.
I'm just sitting here trying to figure out exactly which brand and model speakers to get. I might wait and see what Amazon puts on sale next week for Black Friday.
Cobra31
Sammamish
2021 Bronco/Toyota Highlander
These sound pretty good, and are 40% off right now: https://www.amazon.com/gp/product/B07B8TKWS1/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Although, it was a PITA to pull off 2 of the mounting points on the speaker (The 4 won't fit, at least in the rear, without pulling 2 off. The Bronco speakers only have 2 mounting points).
I also like these for the front (don't fit in the back, the middle part of the speaker sits up too high and presses on the factory grill) https://www.crutchfield.com/p_13699040/JL-Audio-C1-400x.html
I replaced the kick panel speakers (https://www.crutchfield.com/p_13699042/JL-Audio-C1-650x.html), and can hear a difference, especially at higher volumes. But I agree with most others, best bang for your buck is swapping out the fronts. If I would do it again, I'd probably go to a store and test out some higher end front speakers.
PapaWE
Ohio
89 Chevy K2500, 07 HD Nightrain
I finished upgrading the speakers in my Big Bend this past weekend and wanted to give those interested some information that may help--
My Big Bend came equipped with the standard 6-Speaker system and I simply wanted to upgrade the speakers to give the stereo a little better sound. I previously owned a 2017 Jeep JK Sahara that I used some Kicker speakers so I decided to go the same route as I liked the sound from the Kickers.
I got 2 pairs of 4in (46CSC44) and 1 pair of 6.5in (46CSC654) Kicker CS speakers. From my previous install on the Jeep, I learned that using speaker baffles was a good idea so I also purchased Boom Mat speaker baffles. For the 4in speakers, I used some Posi-Twist connectors and added a pair of 300Hz Bass Blockers for the front only.
For the 6.5in I used the Metra 82-5605 Mounting Brackets as well as the Metra 72-5602 Wiring Harness.
The speaker installation was straightforward the most time-consuming part is taking apart all the plastic trim which I am so glad some on the forum had already submitted so I was ready with all the appropriate trim removal tools and knowledge.
I have included the documentation I used to remove the trim panels and wiring diagram and well as photos of the install and of the products I used.
I hope this information will be useful for some.
EDIT:
I am adding some pigtail connector diagrams that were submitted by another user on the forum (credit to FLIP). The diagrams will show color wires and their polarity.
This is really a great job. I am looking for a specific answer I don't believe I have found yet. Are the speakers for the kick and dash wired separately from the head unit? Or more specifically , does the head unit see each speaker as a 4ohm draw all around or are the fronts seen as a 2ohm draw and the rear speakers seen as a 4ohm draw. Hope the question makes sense.
FATHORSE
Stephen
okc
nissan
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram F417D628-2309-47A3-8879-5029407F599E
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 67A710B4-8094-4D25-9F38-CEAAEFD899CC
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram E0A3A11F-6CAD-4E0D-82A0-31016BC16CFE
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 4B3ABA9A-4C15-418A-8FF8-3ABD1D3E819C
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 98CF4CA6-6CA8-4D55-8AFE-7D512715B0D2
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 47A83E4F-BE3C-4CC7-8180-E17F47FC45CE
There are 4 panels plus the handle and the plastic cover for the foot rest that need to be popped out. There are 2 10mm bolts holding the foot panel down. You have to use a extension to remove them.
FATHORSE
Stephen
okc
nissan
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 0BAFD19F-7E47-475F-984C-17273DDC9969
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram F20364CE-A8D2-48F6-8A2E-B5E92E5CCC68
Super Thin tabs on the panels, use caution when removing. This one on the speaker wire and one on the Foot rest panel broke off.
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram DE464725-AF2B-434C-9965-1F9480E0C340
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 4F892D5A-EF95-48A7-8577-DED1EB886CBD
Used a drill bit to puncture the rubber grommet slightly larger than the power cable to run into engine bay. Not shown in picture. Also my finger nails got dirty and I burned my finger on the soldering iron. So I would recommend wearing gloves.
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 92C27FDF-4576-49BE-99DB-4CA50A22A525
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram DE0A344D-B1E8-48D3-8477-BAB4306EBDDF
FATHORSE
Stephen
okc
nissan
Solder and heat shrink after determining the positive and negative for sub amp an speaker wire.
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 8D266D09-5F42-4A2E-B47A-48DEA1D3E0AD
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 1C601492-BEC1-4F02-ABFB-5F6F0451E67B
I only connected to the left kick panel. See wire diagram from previous listing and the diagram from the kicker instruction manual.
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 1865DE56-B5D7-40AD-B5A2-0580BF03FCC8
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 605CC789-D1F2-44E3-A5CB-CCAD68380AD2
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram CC57A8A1-3F49-47B3-98B5-958610AEEE46
Was going to connect to amp fuse but ended up using 21, because it was only hot while the truck was on. Chart shows unused which worked out perfect
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 5C0CACA6-90C8-41DD-915A-DF4E2DCB31B5
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 429CF6A0-1A74-4858-B53C-D0BAAFF5C4C5
Highlighted location for amp, always on, do not use or will drain your battery!!!
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 88684110-B79B-4F48-8AFB-1C0319599F79
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 159361E4-C578-4A63-96B2-336BE7998291
FATHORSE
Stephen
okc
nissan
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 88C87057-7145-463B-B6D9-DF6BE616156A
I tried D-pinning the connector, successful with one, but ended up having to cut and solder the other one of the two that are on this plug.
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram F2C99D11-BD54-4C7A-B7A0-08EEF12E1E0D
They had this at the local Auto Zone, I went ahead and purchased some extra 10amp micro2 fuses. I believe it is the unused fuse location 21 if i remember correctly.
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram DD0EDD26-9118-4F66-AB68-03D8D37E14A6
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 80DA0D19-E85F-4DE2-B94C-7A672A8997B2
You can see the location in the fuse box here. This is the Blue wire off the amp harness that sends a 12v signal to the sub/amp to turn on and off the sub. It is not powered 100% of the time, only when the key is turned to the on position.
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram BAA9135F-D54A-4DF7-9166-696687DAA244
The sub will not fit under the seat on the 2 door without making modification to the carpet. For some reason there is a hump in the carpet but there is nothing underneath it. Maybe for a higher end model component ? I will leave mine in this position.
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram 5675BD13-1F5A-43DE-81F0-C641D5CCED5E
The back seat is able to fold down without touching the amp/sub.
Contact
Randy
Austin, Texas
Bronco Big Bend. FJ Cruiser
Anyone have any luck with a under seat powered sub like this? https://www.crutchfield.com/p_20611HS8/Kicker-11HS8.html
I'm not looking for anything crazy (or obvious, still have some PTSD from having after market systems stolen as a kid), but looking for a little more base than what I currently have. I've already upgraded the fronts and kick panels.
I'd like to try and tap into the kick panel speakers, I don't know if plugging into the factory head unit will work, and it looks like a real PITA to even access.
Tapped into KP speakers and mounted the Kicker 11HS8 to the back of the rear seat. What a difference the sound is with all the speakers replaced.
BroncRik
BroncRik
Naples.FL
Explorer Sport
I think you are asking if the speakers are wired in parallel or series. they speak about it on this post and the OP might have some answers for you if you send him a message directly.
https://www.bronco6g.com/forum/thre...-with-stereo-wiring-diagram.20275/post-730461
Cobra31
Sammamish
Ford Bronco Bronco standard sound system 6 speaker upgrade DIY writeup w/ instructions (dash & kick panel speaker removal) & wiring diagram AB16B86B-3E6E-4880-B4C3-1EE7B56B36AF
How did you tap into the KP speakers exactly? Did you need to tap into both sides and/or buy additional hardware/wires/connections/etc.?
I'm totally new to this so sorry for being obtuse!
Contact
Randy
Austin, Texas
Wiring comes with sub. Tapped both. Do not tap into rears
FATHORSE
Stephen
okc
nissan
Updated the pictures and notes, Sorry for the shit show, it has been a very stressful week for me.
A lot of that stuff is out of order and cryptic, but def worth doing. Was Jamming out driving around tonight, where as before I was NOT. Everyone absolutely needs to upgrade to a sub when you get your bronco.
Rickey498
Rickey
St.Louis, MO
Ford F150
Has anyone tried to see if you can add a third 4” speaker to he dash like the BO system?
