Bronco suspension lift - lift kits vs spacer lifts?
gjennings12
Grayson
Houston
F-150
I am very inexperienced with lift kits. I want to purchase a suspension lift kit (3 in front, 2 in rear). Do suspension lift kits require you to change the shocks in your vehicle? I don't want to get rid of the bilstein shocks in the Sasquatch package because they are already good. But I heard suspension kits are better than spacer kits. What is the disadvantage with spacer kits? I am planning on running 37s on my bronco and I heard a 2 inch lift is what is needed.
Advertisement
goatman2
Richard
Bakersfield
F450, Jeep XJ
Nothing wrong with spacers to keep the PSD Bilstein shocks. Do you have Sasquatch or a BL non-SaS? Might do a bit of research to see how much lift you need to run 37's. Also research when you'll need upper A arms. There are many types of spacer kits on various types of vehicles, so no general rule on it. Since the Bronco already has coilovers adding a spacer to add lift is very effective. Still must check upper arm movement range and CV axle range depending on how much lift.
MaverickMan
Shane
Travel range is the difference between spacers and longer coilovers. Also the longer coilovers have larger volume which reduces heat, and resists fatigue. However travel is aslo limited by control arms(hence the name control) aswell as CV axles in the IFS(front) and driveshaft (rear). However at the small height lift you are after travel wont be a major loss with a spacer. The only thing you will be losing is the ability to run offroad endurance racing(so not a big deal I imagine).
Bottom line is that there are a few realms of lifts. Poor mans, skilled poor, wealthy bolt on, and skilled wealthy.
If you just want a lil height a spacer is fine.
If you got skills, bust out your welder and make your own lift probably $50 in scrap metal and wire. If you got money just throw it at it.
And if you got money and skills you must have brain farted to need to ask this.
Advertisement
Advertisement
