The twist was never the issue...the issue is that with 7 quarts the oil level ends up about 1/2 above the max mark on the stick. Yes, that puts the oil level in the middle of the current twist, but moving up the twist would simply mean that the oil level would still be 1/2 above the max mark. Hopefully the stick that is supposedly now in the database and indicates as the correct one for the 2022 Bronco has a max mark that is at least 1/2 higher than the sticks most of us have.From what I’ve been told the twist has been moved higher up to avoid accumulating drainback oil causing issues with reading the oil level
