I only see the one oil cooler in the workshop manual (same one as the 2.7)wait, isn't there also more oil coolers? or is it just an extra transmission cooler? thankfully this mod would be way down on my list of things I want/need.
For the last 180+ days I've not gotten a good nights sleep. I've been diagnosed with a roaring case of "dipstickphobia" complicated by deep "lubricant-level-uncertainty." I have exhausted the maximum amount my healthcare provider allows for counseling services. I decided if I ever wish to get better, I must stop reading this thread. This morning I confidently strolled out to my Black Diamond, popped the inside hood release and learned how to release the outside hood latch. My yellow dipstick handle has a large "H" on it. I took a breath and like Arthur removing Excalibur from its stone sheath, I pulled that puppy out with one smooth yank. The shiny end of the dipstick extended up to the top mark on the old yellow "H" tool. Whew, I dodged a major caliber bullet. I'm expecting a good night's sleep tonight. Sayonara, boys and peace out!
And there you have it...six quarts in your pan! Well done.For the last 180+ days I've not gotten a good nights sleep. I've been diagnosed with a roaring case of "dipstickphobia" complicated by deep "lubricant-level-uncertainty." I have exhausted the maximum amount my healthcare provider allows for counseling services. I decided if I ever wish to get better, I must stop reading this thread. This morning I confidently strolled out to my Black Diamond, popped the inside hood release and learned how to release the outside hood latch. My yellow dipstick handle has a large "H" on it. I took a breath and like Arthur removing Excalibur from its stone sheath, I pulled that puppy out with one smooth yank. The shiny end of the dipstick extended up to the top mark on the old yellow "H" tool. Whew, I dodged a major caliber bullet. I'm expecting a good night's sleep tonight. Sayonara, boys and peace out!
The Bronco Raptor comes with a reinforced chassis and an upgraded suspension setup... there was the need for a little modification of the outside oil panI’m thinking the same thing.
Bronco 2.7 oil pan: MB3Z-6675-B
Bronco Raptor 3.0 oil pan: N2DZ-6675-A
If they’re both 7 quarts, why even change the pan? Both engines are practically identical and they’re both going in the same chassis. Until we see both I can’t say for sure what the difference is, but this makes it seem like the 2.7 is 6 quarts (like Ford now says) and the Raptor 3.0 is 7 quarts like they’ve always said.
Lol do you have proof of this? Or are you sharing more incorrect information?there was the need for a little modification of the outside oil pan
So you are saying since the oil pan removal procedure is the same... then the oil pans are the same??? Hummm... thought you said they were different part #s... guess I was wrong... must be the same pan....Lol do you have proof of this? Or are you sharing more incorrect information?
Reinforced chassis and different suspension plays no part in oil pan design as far as I can see. Nothing has changed anywhere around the oil pan making it necessary to be different. Raptor 3.0 oil pan removal procedure in the workshop manual is identical to the 2.7
html manuals have been updatedI thought I’ve been reading on the forum that updated manuals say 6 qts for the 2.7. I just checked the 6/22 dated one that’s linked from my ford pass app and it still says 7 qts
This^orhe was saying since the removal procedure is the same, there are no frame or suspension changes interfering with the oil pan...
edit to add roll eyes
the way I read the Ford service schedule, oil changes are every 10k milesFor a year(?) Ford has been using an initial fill of 7.5qts of oil in the 2.7 V6 with no associated problems that I’ve heard of.
This roughly equates to a 7qt service fill.
Ford says that now the service fill is 6qts although it’s ok to use 7qts
As for as I know the initial fill is still 7.5 qts.
Go ahead…..pick the above apart……it’s the way I see it.
So, what’s the problem here?
I, for one, do not give a sh-t how many quarts you use for a service fill……I’ll continue changing 7qts of oil every 5k miles like Ford suggested for the first year(?) of the 6G production and they continue to state that it’s ok.
edit……I marked my dipstick
edit…….this thread still entertains me
The problem (here, in this thread, specifically) is the misinformation people keep posting. Owners are free to pour in 10 quarts if it makes them feel better, or drain their oil for 24 hours (even though if they wait 15 minutes and then drain for about 5 minutes they will be fine) or change their oil every 100 miles, BUT the most updated information is 6 quarts. For the sake of at least attempting to reflect accuracy in THIS thread, the 7 quart-ers should simply create their own thread and feel free to post all day long about WHY they decided to ignore the latest information (and move on from this thread).For a year(?) Ford has been using an initial fill of 7.5qts of oil in the 2.7 V6 with no associated problems that I’ve heard of.
