flip
flip
Phil
IN
www.ruxerparts.com
Fords
. My God some of you really go off on tangents!!
Flip, thanks for the info. I’m still unclear what to do. I just got back from my dealership for my first service. The dip stick is at least 1 inch above max. What action if any do you think I should take.
If the invoice says they put 7 in, let 'er eat.
da_jokker
Jeep Wrangler JKUR
I kind of scanned all the post, so maybe it's already been said.
But if folks are only getting six quarts out when they drain, but they're putting seven quarts back in because the dipstick is wrong and that's what the manual says..
How many oil changes before you have so much extra oil in there that you ARE going to cause damage.
Obviously I hope Ford sorts this out and gives us some better information. My second hope is that when I finally get my Bronco, I have the odd luck that the dipstick actually registers correctly like a few others have.
Otherwise, maybe I'll see how many courts it takes to get to the max line. And if it is six, toss in a half a quart to split the difference.
Happy
Jerry
Missouri
CJ5, Wagoneer
1} I drove until the engine was hot. Parked and waited 20 minutes then removed the oil filter.
2} Let oil drain from filter housing for at least 20 minutes.
3} Removed drain plug and waited 2 hours until oil dripped 1 drop in about 20 seconds.
Measured: Engine gave out 6.25 quarts. I put in 6.75 quarts.
I'm either under filled by .25 quarts or over filled by .50 quarts.
EDIT: after waiting overnight dip stick showed oil half way up on the twist.
my dipstick is # FT4E6750BF D454A
USAGUY
Ny
You must be happy
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
So I changed my oil about 4K miles. Saw some questions about fill, but let it drain for 20+ minutes and refilled with 6 quarts of Mobil 1. Came just under the “full” hash mark and thought it was good. Today I checked and the oils level was just a bit lower, middle of the “safe” hash marks. I know that I was safe to add, based on the capacity and slight decrease in level, I added a quart of the same 5w30 Mobil 1. Now shows slightly over the full mark. I will be super diligent and drain top and bottom and measure. I will replace what comes out and verify level with a scroll mark on the dipstick. My oil change friends will scold me for not doing so the first time (I was taught this early in my wrenching career and just neglected to follow established best practices). To affirm what many others have said, the quart difference one way or the other isn’t going to burn up the motor or drop a valve. Which of the horrible service managers do you all refer to? IME, they are mostly looking to resolve the issue and get the dealer and tech paid for their work. Nothing more or less. Happy Thanksgiving 🦃!
da_jokker
Jeep Wrangler JKUR
And after waiting at least 15 minutes, where was it on your dipstick?
Happy
Jerry
Missouri
CJ5, Wagoneer
da-jokker: the oil showed right at half way on the twist of the dip stick.
that is very close to where it showed on factory fill.
Carolina Jim
Highlands
2021 Bronco 2-door
Exact same for me. 1,100 miles in...I asked the dealer tech to check dip stick level after adding 7 quarts; he was happy with it. Waited overnight - same stick# and reading as you. If its wrong, at least we have a lot of company
Lake Tahoe Traveler
Sf Bay Area, CA
2022 Bronco 2dr BL SASQ, & 1975 Bronco Ranger
What I don’t understand is…. (And I’ve built several engines with modified baffling and wind age trays) with the same dip stick inserted into the block… you fill to the same oil level. For example if you install a large capacity pan you would add more oil, but the actual level on the dip stick would be the same.
If ford built a larger pan for the 2.7 Bronco to handle 7 qts…. The max fill mark should be at the same level…with the same dip stick….
This concept of adding a 7th quart and rising the oil 1” past the max fill mark (into the twisted section) makes Zero sense….
If the crankshaft is splashing in oil it’s not a good thing… In addition, making excess blow by at full boost with the turbos… along with an overfilled sump, would be a recipe for disaster….
This whole oil level thing is NOT trivial. To guess what the max fill oil level should be (without sound reasoning), is crazy…..Ford needs to address this issue immediately….
Ford if your listening, please help us out here!!!
broncorik
1000% agree...finally a fellow engine builder who understands both the importance of not overfilling but also the concept of the same oil level height regardless of pan depth...and as a bonus the implications of too much oil in a boosted engine...
dcg2
Don
PA
Honda CR-V
Thank you posting this, I've been at the my local dealership dealing with this the entire afternoon. I left with 6 quarts in the truck as that's what the dipstick reads. I was actually thinking it might be some kind of oversight with the dipstick design for the Bronco. This is concerning as many people like myself intend on keeping this truck for a long time. @Ford Motor Company needs to adress this immediatly to prevent engine damage!
@Ford Motor Company can I get your job??? A week has gone by with no information from the company you represent about this VERY straightforward issue.
I want a job where I can ignore my customers questions for a week without so much as providing a "we're looking into it" update to them.
WRF3MD
Will
Maryland
Ford F150/Ranger
So are we calling it 6 1/2?
the Duff
East Moline, Illinois
Ford Fusion
Bumping this. I am currently prepping a FE with the 2.7. The oil level is dead nuts at the top of the hashes. This was after the 15 minute drain back. Just seeing if maybe they updated the dipstick. The engineering number on this one is FT4E-6750-BF.
cowman
cowman
texas
ford
Germans are way ahead when it comes to oil level warning systems...if our Broncos had a low (and high) sensor, like a BMW or Mercedez has, I wouldn't stress about a dipstick as much...however, both my Sprinter and my former G series had not only sensors (for those who prefer dash warnings) but also very accurate dipsticks (for those of us who don't trust the fairly inaccurate "ballpark figure" sensors). Point again being that Ford in this particular case is irresponsible for not being able to build a product that has an inaccurate dipstick (or oil capacity indication). How hard can it be to make a car that has a manual/vehicle in which the oil level rec. matches the provided instructions/dipstick? Also...as you pointed out your BMW did not have a dipstick. If our Broncos didn't have a dipstick, this entire topic would be pointless. Because our Broncos do have a dipstick, however, and because they are apparently inaccurate, Ford needs to give us some direction IMHO.
Ford has given direction..... 7 qts....
