- Matt
- Feb 19, 2023
- 1
- 6
- 32
- Midland, TX
- 2022 Badlands 4 Door Area 51
- Badlands
Matt
Good stuff. I traded in my 2014 4Runner Trail when I took delivery of my Bronco. I miss the Yota but very happy with the Bronco.
Matt
I was running around 10 psi and regular 4L. Lockers front and rear as needed.Thanks! Good video. What psi did you air down to and which 4wd mode did you use? Lockers?
Well one of them (the first one) had 285/75R17's, actually the same tires I have on my 4runner right now. The other 4runner's tires appear to be very similar in size. Theoretically (not all tire mfg's match stated size to actual size), the Bronco's tires are only 1.2" wider and .6" taller, so there's not a ton of difference in tire size.What kind of tires did the 4runner have?
Were you running the stock Goodyear tire?I was running around 10 psi and regular 4L. Lockers front and rear as needed.
Yes sir. The jury is still out if I like them. I've ran BFG KO2 for 20 years. The stock tires on the bronco are louder on the road, and time will tell if they hold up.Were you running the stock Goodyear tire?
