Bronco White Tops, Multiple Vinyl Interior Colors & More Confirmed at Ford Employee Event
rmc523
South Florida
2009 Ford Flex; 2018 Mustang GT
All I know is if I can't get mine with a black left front panel, white front right panel, black 2nd row panels and white rear section, I'm cancelling my reservation.
Cooknn
David Cook
Bonita Springs
Ford Focus
Gad I am so all over the board on this. Since the beginning I thought I wanted the retro wheels, white top and grill. But after spending an hour in Photoshop this morning I’m thinking I’ll contrast my Badlands AMB with the stock Carbonized Gray top, wheels and grill. My wife says my choices are evolving ?
Nickp
Nick
Phoenix
I'm looking for the answer to this as well. Would love white roll bars
I’m thinking a super cool look would be the white roll bar prototype but instead of cactus, velocity blue. I think that would look SWEET
Markubis
New Hampshire
Ford Focus, Ford Ranger XLT, Can Am Ryker
Speaking of roof colors..... ?
I like the white roof with CG, but with A51 will go with black....
That being said and knowing the availability of matching color roofs....My question is can you mix and match them? Can you do A51 body and CG roof for example?
sorry if this has been asked.
If that is your plan then just order a color matched roof and have it painted whatever color you want at a body shop.
Karl_in_Chicago
Karl
Chicago
NO!!!! It must be black RIGHT front panel and white LEFT front panel! There is only one way - and you have chosen the wrong way.
Ford Bronco Bronco White Tops, Multiple Vinyl Interior Colors & More Confirmed at Ford Employee Event frank-forshin-star-trek
WildBronco
2019 Ford Escape
Still no word on color options for the roll cage (if any), right? Is the best guess that it will be body color?
I can almost guarantee they won't do a two tone. It will be body colored.
BodieMonster
Bay Area, California
Civic Type R, VW Atlas
I figured that would most likely be the case... Just wish I could unsee that CG launch model!
Aman
Aman
Northern NJ
that's backwards. the passive drain requires no user action. the active drain requires the user to pull the plug out of the hole.
If you care about how water exits a Bronco it probably helps to care about the two methods Ford has provided to achieve that function.
Passive is a defined term, it doesn’t require user intervention. The passive ”openings” will drain water without you doing anything. Standard on all trims.
Active requires user intervention - pulling a plug. It will drain water much more quickly - suitable for hosing out a vehicle. Not available on all trims.
These two posts are correct. It's amazing to me that so many people don't understand the simple concept of active vs. passive.
Rick Astley
Up Doug's ass
d
The entire cab with roll bars welded in is sprayed at the same time with the same paint. So the only possibility of having a different color roll bar than the painted surface is if there is plastic cladding over it, or you can apply vinyl.
All body pillars (A, B, C, D) will be color-matched to the exterior paint under whatever covering/trim they put over the top.
Goetzsome
Gary
Long beach, ca.
2008 jeep Rubicon Unlimited
Thank you for getting the answer to this! Although, I had come around to liking the white handles, I prefer body colored handles.
I would actually prefer chrome door handles with the white top. I'm gonna see if thats possible without waiting on after market to catch up. And a chrome grill, almost forgot. That would be super retro.
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
Multiple Vinyl colors, in the same seat?
bluezombi
Louis Pierre
Montreal QC
bicycle
Its a roller coaster of things... Guess ill find out later on.
Might wait a bit to make another reservation. Just to make sure that i am far away in the list since i dont mind waiting.
