BroncoSarge Badlands Build
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
2021 AMB Bronco, 2021 CO Bronco
I have been working on my rig for a while now. Not sure how far it will go. As more accessories come out, I will modify the post.
Installed Mod’s:
2-Channel Amplifier by Alpine
Dashboard 4” Speakers by Alpine
Kickplate 6.5” Speakers by Hertz
Rear 4” Speakers by Alpine
Color Match Beadlock Rings
Moved keypad to the fuel door
Fender Delete by 4WheelParts (only when doors are on)
EZ-Lift Soft Top Assist by IAG Performance
Repainted the CG grill to match the bumpers (Textured black)
LED Letter Badges by Oracle
Color Match Tailgate Ford Emblem by BFN Truck Shop
Black Bronco Rear Emblem (Factory Part) by Ford
Third Brake Light Ring by Rugged Ridge
Untenna by CravenSpeed
Deluxe Raised Lid Cargo Area Enclosure (Factory Part) by Ford
Taillight Covers by GTS
Valve Stem Caps by Baron & Baron, INC
Under Hood Fuse Box Lid Label by StickerFab
Under Steering Wheel Fuse Box Lid Label by StickerFab
Seatbelt Retention Buckles by StickerFab
Grill Letter Overlays by StickerFab
Wheel Cap Overlays by StickerFab
X20 Waterproof 10,000 lb Winch w/Synthetic Rope by SmittyBilt
Control Pack Relocation Kit - 78"" Wiring by Warn
High Winch Mount by Rough Country w/LED Light Bar
Black Hawse Fairlead by Grimm
Horse Sound Horn by Boomblasters
Door Sill Guards by Bestaoo
Tailgate Antenna/Flag Mount by Maiker
6ft Flag Pole by Yeesun
Windshield Sun Shade by Savadicar
Billet Winch Shackle by Agency 6
Bronco Hitch Cover by Muslogy
Door Handle Pockets by Muslogy
2“ Trailer Tow Hitch Assembly by Snailfly
IF YOU’RE WONDERING HOW MUCH LIGHT THE COVERS PREVENT AND REDUCE TAILLIGHT VISIBILITY. IMAGE WITH LEFT COVERED AND RIGHT WITHOUT COVER TO SHOW LIGHT EMISSION UNAFFECTED.
Advertisement
dfresh73
Doug
Kentucky
Range Rover
Awesome build. What did you use for painting the grill?
BroncoSarge
BroncoSarge
Jeffrey
BroncoSarge
BroncoSarge
Jeffrey
Some updated photos. Just took off my Badlands stickers and gave her a quick bath. Have been putting winch, Oracle fogs and hitch on wife’s Bronco the past few days. Will get back to mine this week for sure. Pretty hot here.
I was asked about sensors and the wiring path for the winch relocation. Here is those shots.
BroncoSarge
BroncoSarge
Jeffrey
Added these:
Advertisement
BroncoSarge
BroncoSarge
Jeffrey
Update: got the fairlead and rope installed.
BroncoSarge
BroncoSarge
Jeffrey
Added flag mount, flag and pole. Going to grab an American Flag and a Patriot Guard Riders Flag to use. Have two more 1.3’ pole sections to make the pole longer.
BroncoSarge
BroncoSarge
Jeffrey
Finally got cool enough outside to install my tow hitch. Was easier since I did wife’s before. Glad I have a torque wrench. Need this puppy and my bumper snug.
Waiting on the wiring since I really want to have both 4 and 7 pin. Gotta work up the courage to Forscan.
WpBenGman
Installed Mod’s:
Could you tell me which maiker flag/antenna mount that is? And if it isn't too much trouble, your opinion on if it would work with a tailgate reinforcement plate? Thanks!
BroncoSarge
BroncoSarge
Jeffrey
https://www.amazon.com/dp/B0B2WFV2CH?_encoding=UTF8&psc=1&ref_=cm_sw_r_ud_dp_H9JYSD8KH0JCSTZA698X
Overall I like it. The one issue is the length of the handle that screws in to hood the pole in. The thing at the top there. It’s too long to spin easily without hitting the tire. I will probably grind it down a half inch. For now I remove it when the flag pole is not up. The screws they send seem long enough. Should work with the plate. If not, getting longer ones shouldn’t be hard to find.
Advertisement
BroncoSarge
BroncoSarge
Jeffrey
North Topsail beach run. Handles great in sand mode. Didn’t even need to air down.
WpBenGman
Thank you!
98infinity
Alberta
16 F150, 20 Road King, 22 Bronco
I see you have the rough country winch Mount. How do you like it? I was worried about it rusting...what do you think.
SasquatchMansquatch
4 door basquatch
This is freakin sweet.
BroncoSarge
BroncoSarge
Jeffrey
Haven’t had any issues so far. There will always be rust as time goes by. Number of rust inhibitors out there from WD40 to rust proof paint. Truck Bed Liner at Walmart works pretty well at recoating as needed.
Advertisement
