Bucking the Sasquatch Fever
Lab00Rat
MS
Toyota Tacoma
After reading as much information on Badlands trim level, I cannot say I would want the Sasquatch package.
2-Door Badlands, 2.7, and Auto sound exactly what I'm looking for.
The Sasquatch package fever has not captured me over what the BL should be able to do right out of the box. Seems that I might lose some articulation by adding the Sasquatch package.
Lift, 35" Tires, and 4.70:1 final are not enough to convince me that the BLs will gain significantly over the 33" tires.
Am I on my own thinking this way, or did I miss something that should make a significant difference?
Does the Sasquatch package make for a better package on different trim levels?
Who else is not sold on Sasquatch (yet)?
Advertisement
nminus1
Henry
High Desert So Cal
Chevy Duramax and Ford Bronco in 2021
Well the Bilstein suspension and lockers, (which btw are iron cases instead of aluminum case) are a good feature. Just saying...
If 33's and open lighter duty diff, and less gears are not important then I agree skip the Sasquatch.
Personally I wanted the 2.3 and 7 speed manual 2 door with the Sasquatch but it appears that is not possible as the Sasquatch and manual are not offered together.
I reserved a base so it appears now I will add the 2.7, auto, and Sasquatch I.m not going thru this wait, and financial commitment and getting "almost" what I should get and would not be happy with just to save a few grand on what will certainly be a 40k+ truck. Get what you really want is my advice
Drex
Jake
The Bandlands gets both locking heavy duty pumpkins and the 4.70 in the manual. 4.46 IIRC in the auto.
nminus1
Henry
High Desert So Cal
Ok I was not aware. I thought the 4.7 was only available in the Sasquatch. Will have to review the specs again. Also sweaty vinyl seats are a deal breaker I want breathable cloth seats, auto swaybar disconnect is not on my list.
I really think the build spreadsheet coming out next month (hopefully?) will reveal what costs what, and what is worth what. That will be the key in my mind on deciding what model/options to get. For example, a Sasquatch package addition to the Badlands should not be the price hit as other models as obviously it already has some of the Sasquatch features included, etc
Darforce
Darlene
Buffalo, ny
Subaru crosstrek/ Mazda miata
I was sold on the sasquatch till I found out you can’t have it with manual transmission. if I’m getting a vehicle like this I want manual.
CJay
Chad
WI
'08 Ranger FX4 (MANUAL) & '74 VW Thing
Originally I was disappointed that Squatch was only available with auto... but then I realized the BL had everything except the 35's and bead lock capable rims (and possibly some extra lift) which I really don't need.
BL Manual!!!
Parker
PA / CA /AZ
Gr Che Overland, Corvette, Tahoe, 46 Chevy 2ton
When build goes live it will be interesting.
I was thinking Black Diamond with Sasquatch, dump the big 315/70 mud tires and idiot, heavy, hard to balance rims and go with LT 285/75 (75) 17 AT, maybe steel rims - 33.8 inch to 34.3 inch (Cooper AT3 comp), much less weight and noise, close enough to keep computers happy .
That would be very similar to stock BadLands and potentialy a few thousand $s cheaper in a 4 door. If it was not a big savings not worth it. Only the build Release will tell.
BroncoJay
Iowa
Tacoma
I love a big tire but as someone who plans on using their bronco as a DD I’m wondering if 35s would be overkill...
I keep debating the base with the squatch or just upgrading to the Black Diamond without the Sasquatch...
what are the thoughts out there with the squatch package? I won’t be doing much rock climbing, just off road, fire road stuff, I’m a mountain biker and love the idea of the marine grade rubber floor stuff...
Advertisement
Advertisement
