Bull bar light to the OEM AUX switches?
LittleMule#1
Andrew
Cleveland
2023 WILDTRAK, 2019 Expedition MAX
What is the easiest way to wire a 13” LED Bull bar light to the factory AUX switches?
HotdogThud
mk6 gti, '21 MoarDoor
LittleMule#1
LittleMule#1
Andrew
Cleveland
put in place, then pull up the upper cowl above the grille and remove, run the wiring along the front to the driver's side cowl and tie into a circuit there, then just ground the negative to the ground point above the brake booster.
it's what I did here: https://www.bronco6g.com/forum/threads/pics-of-your-safari-bar-please.43427/post-1388087
Thanks- I thought it was that simple. Now, can you buy any chance send me the THREAD link to which number switches in the cab are which color under the hood? TIA
Herbie
Alex
Cleveland OH
2022 Badlands
Ford Bronco Bull bar light to the OEM AUX switches? 1651623494320
Aman
Aman
Northern NJ
Herbie
Alex
Cleveland OH
2022 Badlands
Those are the old specs. The current ones can be found in the user manual and the chart below.
Ford Bronco Bull bar light to the OEM AUX switches? Identifying the Auxiliary Switch Wiri
He was just looking for the color scheme (which is the same) but good looking out.
