RainbowStix
A Big Island
Toyota Tacoma
I’ve got this exact tire setup, with just ~1” less backspacing at 4.75”, 3” lift, and a DIY mudflap. Just had the caster raised a bit to the 3.8-4 range so now it only rubs the flap under articulation, and in reverse.
taking the flap off, full steering range under articulation. Since your tires are more in, you should have less rubbing than me😃
and if you really wanted zero rubbing under every condition, my guess is trimming off those crash bar stubbies would get you there
350vudu
350vudu
Cleveland, OH
2017 Shelby GT350, 2019 Ducati V4S Corse
Quick update, slight rubbing when I take it off-road, headed in for a lift
What lift did you get? Any updated pics? I'm going with these same exact wheels and 37x12.5R18 Nitto Trail Grapplers. I'm looking at doing perch collars. Keeping my stock Sasquatch wheels for off-roading.
linbackr99
Todd
Vermont
2017 Raptor Crew
CactusClub
Jordan
Canada
2021 Bronco Wildtrak, 2021 Porsche Taycan, GT3RS
I added a 30mm spacer and she now rubs😞
CactusClub
Jordan
Canada
Yeah wanted a little more of an aggressive stance
350vudu
350vudu
Cleveland, OH
Your wheel was 9.5 wide with +12mm offset. I would assume that would give a decent poke. Any recent pics of the setup?
davidbitton
Bergen County, NJ
'22 Wildtrak
I have a Wildtrak, and I'd like to fit the BFG KO2 LT37x12.50R17 tires that are stacked up behind the shop right now. The tires are mounted on black rhino armory 17x9.5" -18 offset wheels. I'll need a set of adapters because these were on an F250 with an 8-bolt hub. The spacer/adapter is 2" (50.8mm). Does that make the offset -68 or +32? Thanks.
Lurker B6G
Murph
Cleveland, OH
Ford Explorer Timberline
-68 which is CRAZY o_O
Stock Sasquatch is +30 (same 12.5" tire width), and you will be 4 inches pushed out from the stock position (which is already an inch further out from the base model +55).
Ford Bronco Cactus Gray WildTrak on 37s - No lift 1652280519627
davidbitton
Bergen County, NJ
'22 Wildtrak
hmm, that's quite a bit of extra stick-out. thanks!
Freedom5
Freedom
Snohomish Washington
Classic mini cooper
I'm gonna have my 37s mounted tomorrow. 37x12.50R17LT and wheels are 17x9 -12. I have a zone 3" that will be installed at the end of the month
Ford Bronco Cactus Gray WildTrak on 37s - No lift 20220816_123543
Ford Bronco Cactus Gray WildTrak on 37s - No lift 20220816_123143
