Can Forscan program the doors to automatically unlock when key fob is in range?
r21free
bob
michigan
2021 bronco badlands
  • Thread starter
  • Banned
  • #1
On any bronco could you use forscan and program the doors to automaticly unlock when key phobe is in range? And lock when your out of range.
dan79
dan
ma
08 f250
i hope so! that would be perfect for me
Jabberwock
Craig
Georgia
2011 Toyota Tundra
I wish you could program to have the windows do the auto-drop when you grab the door handle sensor. By the time you pull the door open the windows never drop in time.
This!
You would think Ford would have done this from the factory. Just set it so if the door isn’t opened in a certain amount of time, the window goes back up to its original position.
kput
Nebraska
2006 Honda Ridgeline, 2021 Bronco 4door
This feature exists on 2021+ F-150 Lariats and above. The setting exists somewhere 🤷
International_George
George
Kirkland, WA
1980 International Scout II
Don’t they already do that? When I get close to mine it lets me open the door without using the fob buttons.
JHForman812
Floyds Knobs
2022 Super Duty
I believe this is called approach setting, unless you have the receiver for it it wont work.
JHForman812
Floyds Knobs
2022 Super Duty
thats normal proximity handles. theres a sensor built into the handle that as long as you have the key in your pocket and grab the handle the door will unlock this is normal operation. what the OP is looking for is approach detection. I dont know that this is a feature the bronco has.
Buck Your Bronco
charley
Sylva, nc
2021 bronco
It’d likely be under:
726-18-01. Change to:
0101-0101-01xx
might be others, but I found this on the f150 sheet so worth a try. Not sure about the hardware
BroncocnorB
Paul
1965 Cobra,
On mine if I hit unlock on the fob, then hold down the unlock button, the windows retract on approach.
WuNgUn
Ontario Canada
2 door Squatched
And you can also close them with the holding the lock button... If you enable it with ForScan.
WuNgUn
Ontario Canada
2 door Squatched
0101-0101-01xx
What are the person settings I wonder? Enabling the setting per door?
