- Banned
On any bronco could you use forscan and program the doors to automaticly unlock when key phobe is in range? And lock when your out of range.
This!I wish you could program to have the windows do the auto-drop when you grab the door handle sensor. By the time you pull the door open the windows never drop in time.
This feature exists on 2021+ F-150 Lariats and above. The setting exists somewhereOn any bronco could you use forscan and program the doors to automaticly unlock when key phobe is in range? And lock when your out of range.
The rear doors don'tDon’t they already do that? When I get close to mine it lets me open the door without using the fob buttons.
I believe this is called approach setting, unless you have the receiver for it it wont work.This feature exists on 2021+ F-150 Lariats and above. The setting exists somewhere
thats normal proximity handles. theres a sensor built into the handle that as long as you have the key in your pocket and grab the handle the door will unlock this is normal operation. what the OP is looking for is approach detection. I dont know that this is a feature the bronco has.Don’t they already do that? When I get close to mine it lets me open the door without using the fob buttons.
Not on the base. I found this thread while looking for possible ways to add it after.Don’t they already do that? When I get close to mine it lets me open the door without using the fob buttons.
And you can also close them with the holding the lock button... If you enable it with ForScan.On mine if I hit unlock on the fob, then hold down the unlock button, the windows retract on approach.
What are the person settings I wonder? Enabling the setting per door?It’d likely be under:
726-18-01. Change to:
0101-0101-01xx
might be others, but I found this on the f150 sheet so worth a try. Not sure about the hardware
