Can someone exlain wheels and tires in layman's terms?
STRATUS
Tim
Chicago NW Burbs
Range Rover Sport, C8 Corvette Spyder
At risk of sounding totally foolish, can someone please explain wheel and tire sizes, offset, etc., in terms that would make sense to a 3rd grader? Thanks!
BrentC
Brent
Calgary, AB
I can’t explain it any better than what you’d find using a search engine:
Draughon
Daylon
Dallas
BMW 4-Series
This may help - (I asked a smart person about running 37's on a SAS model)
Offset is a measurement that all wheels have. It determines the location of the wheels mounting pad. Here's a good write-up that I put together that will help make sense of it:
https://www.bronco6g.com/forum/threads/wheel-offset-and-backspace-how-do-they-relate.9910/
Offset is not good or bad per se, although I guess it could be considered bad if the incorrect offset is used with the intended tire size. Tire size, wheel width and offset all play a role in the overall fitment based on the vehicles suspension and wheel well clearance.
You can run 37's on the factory SAS wheels, but at near full lock of the wheel the tires will make minor contact with the vehicle frame. You shouldn't have nay rubbing on suspension components though. Here's thread from the forum that goes into this exact fitment:
https://www.bronco6g.com/forum/thre...atch-bronco-straight-off-the-transport.19784/
It's important to note that 37's are the max size. If you plan to rock crawl with your rig you may want to consider a leveling kit to gain some articulation. In stock form, articulation will be limited with 37's
STRATUS
STRATUS
Tim
Chicago NW Burbs
Excellent! Thanks!!!!
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
Folks mention frame rubbing at full steering lock…does the Bronco not have adjustable steering stops?
(Don’t have my BL yet, but I’m used to adjusting steering stops on old LRs)
iamcris
Cristian
Lakewood, WA
21 Bronco Badlands
Or slow down, it tightens the radius.
HoosierDaddy
Indiana
All kinds of information available at many tire based web sites.
My current fav ...
https://tiresize.com/chart/
They even have a tab labeled "education".
