Can SYNC 4 recalibrate speedometer?
sliwa
Matthew
Ford Focus
I’m still driving something with Sync v01, so I was blown away with the capabilities of Sync in the Sport that I test drove (Sync 3, or did the Sport get 4 also?).
With everything that Sync seems able to do now, is there any reason why it doesn’t have the ability to update tire size and recal the speedometer? Doesn’t seem like it would be beyond the capabilities of the system, but is there something else I’m not considering??
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Sync doesn't have anything to do with the speedo calibration. That's part of the power train control modules somewhere. Forscan or other OBDII tools can recalibrate the speedo. I have one that has the capability, but you have to pay "extra" for the software I believe.
sliwa
sliwa
Matthew
Ford Focus
Makes sense, but still seems odd to me that one system in a truck can’t communicate with the other. 🤷‍♂️
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I think the opposite. Way safer to silo these systems.
Could you imagine if Apple CarPlay froze, and as a result your turn signals stopped working?
2Jeeps&PatriotX1
Denver, CO
Forscan is your solution. Have sync 3 in my truck. Looking forward to the sync 4 system.
wilbersk
Sean
2023 Bronco Raptor
This seems weird to me, because on discount tires website it says most new cars can calibrate the speedometer using the head unit.
vrtical
Doug
GSMNP, TN
Fords
its all good except when you dont encrypt the data traffic on the canbus.
Laminar
Iowa
Cougar
They can communicate. They're all on a shared CANbus. But Ford didn't implement a way to modify PCM and IPC tire size settings via the entertainment system.
This isn't true. I Googled around a bit and apparently some Tacomas can do this? But every other method I found for calibrating the speedo involved an aftermarket tuner or a dealer-only program.
On further review, maybe you're referring to this:
https://www.discounttire.com/learn/speedometer-accuracy
Most modern vehicles can have the tire diameter changed in the vehicle computer, which will recalibrate the speedometer properly.
"Vehicle computer" - not the head unit or entertainment system, but the PCM/ECU. Modifying this requires an aftermarket or dealership tuning tool. Or for Fords, you can edit it using a laptop with Forscan.
wilbersk
Sean
2023 Bronco Raptor
Thanks for the clarification on that!
