- Brice
- Jul 6, 2020
- 72
- 1,535
- 4,426
- Louisville, KY
- 2021 Bronco
- Badlands
Look up e85 tunes on the f150 forums. 2.7L can handle it stock. Dual injection gives enough fuel for it. RIP warranty obviously but it can be done.1. Your fuel system rubber and plastic parts are not designed or approved for that much alcohol. And the fuel.pumps. I would suspect that if ypu ever require engine warranty it will be flatly denied simply due to your vehicle not approved by Ford for what you feed it. If it required full synthetic oil and you ran non detergent Dino oil as an example.
Edit: brew city boostās website:
https://www.brewcityboost.com/bcb-2-7l-ecoboost-dyno-results/
For those that donāt know the big differentiator between Gen1 (2015-2017) and Gen2 (2018-2020) is the addition of Port Injection (PI) on the Gen2 engines. The Gen1 design only utilized Direct Injection (DI) and with the addition of PI to the Gen2 the fueling system capacity allows us to run full E85 without any fuel system mods, just a tune calibrated for the fuel. What this means for the Gen1 engines is we are limited in Ethanol content, E30 is about as far as you can go without any fuel system mods and E50 is capable with a simple boost a pump or intank fuel pump upgrade like a DW400.
2018-2020 2.7L Ecoboost (Gen2)
Stock Tune : 383 TQ / 306 HP
BCB E85 Custom : 522 TQ / 431 HP
Gains over Stock : +139 TQ / +125 HP
