I like all of these super long answers, "With the proper tune,....".
The answer is No. No you shouldn't run E85.
Actually the sensor is the o2 right? It’s inferred flex fuel. The o2’s relay info back to ecu that can then interpreted in an ethanol content. Because the stoich values are so much different the o2 voltage signal will be different for each fuel. But either way I doubt the maps in the pcm has the table ranges nor fuel delivery capability to adapt fully.A lot to unpack here. Ford has never used ethanol sensors like GM flex fuel vehicles do. They measure vapor pressure in the fuel tank and from that are able to infer the ethanol content of the fuel. A little more math than using a flex sensor directly, but it works.
You're right - I was going off an old ASME paper about inferring ethanol content via partial pressures. Ford uses a couple of triggers to detect a fillup, and then assumes rapid changes in AFR readings are due to ethanol content changes and puts those in a new flex table vs. the standard fuel trim tables.Actually the sensor is the o2 right? It’s inferred flex fuel.
In a factory system without Flex support enabled, the fuel trims will make up some difference, but will definitely throw a code before it's able to add the ~30% of fuel needed for full E85. Per my previous links, it can definitely account for lighter blends.But either way I doubt the maps in the pcm has the table ranges nor fuel delivery capability to adapt fully.
Well, They didn't have a dyno with them in the Bronco and there was a Mustang on the Freeway.A couple things, as stated your mpg will be dramatically reduced and I find it difficult to believe without seeing actual dyno results it increases hp without tuning. Flex fuel compatible vehicles have ethanol content sensors in the fuel system which commands different fuel maps, timing maps and probably boost to take advantage of the cooler running high octane e85. Fuel alone there should be no benefit without tuning to take advantage of it. With tuning, yes you can make a lot more hp but fuel mileage will still be terrible.
Simply switching to E85 flex fuel won’t instantly increase your engine’s horsepower. Your engine needs:
To be compatible with E85 fuel
To be tuned to improve timing and power
"Wow, so you can read the brochure."I like all of these super long answers, "With the proper tune,....".
Agree lamda is 1.0. I meant a/f is so different for e85 and gas for 1.0 stoic. Technically it is not an o2 anymore but air to fuel sensor but it is the feedback for inferred fuel tables.No, AF ratios are different, but lambda stays the same. So you need a totally different AF ratio to achieve the appropriate lamba value.
Stoich is 1.0 lambda regardless of the fuel being used to the sensor (iirc).
I get it, you can tune the Bronco to run E85, but why? The Bronco is NOT a Mustang. Why anyone would want to void their warranty to pull a few extra HP and run MORE cheaper gas is beyond me. The Bronco has WAY more than enough power to do what it's designed to do, which off-roading if anyone forgot."Wow, so you can read the brochure."
Is it 6 or 7 quarts of oil for an oil change?
I mean it's really like you people are out here trying to rock crawl in a Mustang... Same thing.
Let's not forget the OP's original question, "Can we run E85 in the Bronco?". The answer is no, because without a professional tune you're going to be running too lean which CAN cause damage to your engine.
Did u have to upgrade any fuel system parts?I personally ran E85 in my 2021 bronco for months and countless tanks. Maybe I should make a thread about my adventure.
1. The bronco ran better then ever. The engines timing or whatever was definitely improved to take advantage of the E85 (maybe not fully but still). I barely had to use the clutch to get moving. It really felt like I got a major HP and Torque boost vs 87.
2. The engine will throw a fuel code telling you its adaptive learning reached the maximum potential. This is actually a very useful error because it also disables engine start/stop automatically for you. I just continued to ignore it as it was running great.
3. You will see a SLIGHT decrease in MPG. I was getting around 17 before, with E85 I was consistently getting 16. Many people will start typing "ETHANOL HAS 30% LESS ENERGY THUS YOU WILL GET 30% LESS MPG" wrong. Ethanol due to its much higher octane (105-115) can handle much more compression, and if an engine can utilize the ethanol properly it will increase compression and squeeze much higher levels of efficiency out of it. It cannot do so with gas because of preignition.
Thats why if you tow with a flex fuel vehicle, you will notice that you will get the same mpg as gas or sometimes even better. Turbos love E85 and help increase the efficiency of it.
4. It cranks more for cold starts. E85 is rougher in the cold, let your car warm up a bit longer before driving off.
5. It keeps the engine cooler, longer.
6. Keeps the tail pipe spotless
7. Smells delicious.
When gas was $6 a gallon I could get E85 for $2.69. I will 100% use E85 again if gas goes high, but for now (prices dropped substantially) I switched to 93 since 87 feels lethargic to me and in my area (I moved) ethanol is the same price as gas or more.
What did he use to read fuel trims and knock retard? I’d like to observe those figures but don’t have a handheld tuner or anything fancy. Was hoping there is a monitor I don’t know about.Agreed, I hope to data log something like this later.
No engine codes, no drama, stock maps, no engine mods - fuel trim was about +8% long term trim and +4% short term trim according to my friend. A/F Ratios were fine.
I used my F-150's sct tuner for this purpose and to watch the lambda values. Fuel trims adjusted to compensate easily with 30% E85 + 70% 93 octane.What did he use to read fuel trims and knock retard? I’d like to observe those figures but don’t have a handheld tuner or anything fancy. Was hoping there is a monitor I don’t know about.
