Can't roll all 4 windows up at once.
e90steve
Atlanta, Georgia
Porsche 911
Has anyone else noticed when you click all 4 window buttons at the same time to roll your windows up, a few don't make it all the way up and pause in the middle of the operation? I've started simply rolling the rears up first and then the fronts, solves the issue. But seems strange they can't all roll up at the same time. Wondering if it is like a voltage thing?
Theherofails
Thomas
Phoenix
Yep. Every Bronco I've been in (including my own 4 door) works that way. You have to do the little 1,2,3,4 routine and hope you weren't too fast.
Im curious to see if anyone can pull it off. I've even done the window reset routine just to see if it made a difference - nope.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I noticed this too.
amccue90
Andrew
Illinois
2021 Badlands
Just hop over to the forscan thread and you can use your key fob to roll all windows up remotely
at.....the.....SAME......TIME!!!.......
codydb19
Cody
Silverado
Same. I do the same as you, I roll up the rear two, wait a beat, and then do the front ones and it works.
If I do the opposite and start with the front two and then try to roll up the back ones at any point before the fronts are up all the way the fronts will bounce back and pause.
e90steve
e90steve
Atlanta, Georgia
Porsche 911
I get it, it seems like a silly ask. But it is a bit annoying when it actually happens. Just like why? If there is a good reason I'm willing to accept it, but just seems like a mistake when it does happen. This is while driving down the road, not when you are trying to remotely open them.
babraunagel
Golden, Colorado
Toyota FJ Cruiser
Permanent fix to the window roll-up / stall issue:
Order a 2-door! 😆
