Caught an interesting Wildtrak photo today
Funkdoobiest
Buffalo
Ford Bronco Basesquanch First Edition
As long as there's at least one wheel on the ground.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
What does that mean? Do you think the front sway bar disconnect would make a big difference in that scenario? Maybe it would, not sure? I assume it scrambled up no problem either way?
vrtical
vrtical
Doug
GSMNP, TN
Fords
Yes the front binds up and causes this kind of issue. The driver had to back down a bit to get it level then try again.
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
No, he high sided the right rear, leaving him in tripod position, can't see the front but looks like both wheels are on the ground, disco won't help, just a low spot under that left rear, back up and pick another line no problem. Trial turn assist won't help either as that inside rear has zip for traction.
vrtical
vrtical
Doug
GSMNP, TN
Fords
I am going to disagree with that the front driver tire tells. On a disco that tire will be much closer to the flare and that will cause the rear to act accordingly.
Jmet8
James
South
Toyota
This pic was taken during a trail turn assist demo and is moving as you can see mud fly off the tire that is off the ground. The turn was well over 180° And up a step incline and never even missed a beat.
da_jokker
Jeep Wrangler JKUR
I would think the Disconnect would put that tire back down...BUT it doesn't need to be down. The Bronco isn't off camber much and having a wheel come up makes for cool pics like this!
Dirty Bronco
Brad
Charleston
2021 Ford Bronco - 4 Door Badlands
I get what you’re saying but I think you mean “90 degrees”. A 180 degree turn would put the vehicle pointing back towards the way it came.
Dirty Bronco
Brad
Charleston
Both wrong...135 degrees FTW!
Okay but not what I was saying. He said “over 180” when I said I think he was trying to say “over 90” which in turn means 135 > 90 so thank you for proving my point lol 🤗
Drex
Jake
What I am reading is that a non-Rubicon Wrangler would have had a very hard time making this turn.
Jmet8
James
South
Toyota
it was 8am and raining and a Baha champion was getting at it . I could not sleep the night before because I’ve been trolling on here for 6 months. All i know is we where not supposed be able to make that turn in 1 go. It was awesome which ever degrees it was.I’ll say 98 because it HOT!
