CB Antenna Mount (Homemade) Now With Full Radio Install Pics.
sgraing1
451xx
2022 Bronco Black Diamond.A Bunch More Junk.
This is a work in progress. However,I figured out where and how I'm going to mount my antenna. Don't give much attention to the coax connector. I'm most likely going with a right angle pl259 connector. Maybe this will help others with choosing a mounting location.
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 20220810_134401
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 20220810_134428
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660697863881
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660697952509
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660698054595
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660698151480
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1663895890990
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660698453519
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660698518628
grayshadow
Charles
Humble, Texas
What’s a cb? And why does it need an antenna?
DaveInSA
Seguin, Texas
2021 Bronco Badlands 4DR, 2007 Saturn Sky
Citizens Band radio. License free communications system. Huge in the 70s. Remained huge among off-road and motorcycle community until GMRS (General Mobile Radio System) came around and has been getting replaced quickly by it.
However, there are still a lot of groups that use it and haven’t moved to gmrs for various reasons. Gmrs requires a license to legally operate and all new equipment if you already have cb.
edernest
Ed
2022 Bronco Sasquatch
Cool, thanks for clarifying. I'm not faulting your use of it but was curious. I figured it must be that the folks you know are sticking with it, or something like that.
FWIW, and you probably know this, GMRS does require a license but involves no test and only a $30 fee which covers your family for 10 years. To each his own though, use whatever serves you best.
DaveInSA
Seguin, Texas
I’m not the OP :)
I personally use amateur radio and gmrs.
grayshadow
Charles
Humble, Texas
Yes, I opened my box of 70’s stuff I stored away and found one under an old 8 track Beach Boys tape.
Sven
West Yellowstone, Montana
67 Bronco,75 F250 CS,88 M35a2c,
I have both CB and GMRS depending which group I'm out with well you know the rest of the story.
sgraing1
sgraing1
451xx
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660596496693
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660596773967
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660596837654
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660596890680
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660596962065
Ford Bronco CB Antenna Mount (Homemade) Now With Full Radio Install Pics. 1660597022930
ksdon
kansas
On the Alaska Haul road between Fairbanks and Dead Horse CB is the main truckers communication. They use marked call out areas and expect you to know they are coming round the bend or over the hill.
sgraing1
sgraing1
451xx
Looks like a solid mount location. Not sure if the other poster was joking or not, but I’m curious about your choice to stick with cb over gsrm.
I go on sideband a fair amount (Channel 38 LSB) and listen to and sometimes talk skip. There are also some local CB base stations around here that I talk to.This radio was never used much and was purchased around 1996.Figured that I would put it to use.
If I ever feel the need to go GMRS I will probably start with a handheld unit.
rws
Robert
GA
2015 VW GTI, 2018 Silverado 1500 LT Z71
Nicely stated.
Also if I might add, CB provides low cost, low barrier of entry into staying in communications with those around you while out playing in the dirt. Are there better options? Perhaps, but that depends on one's definition of "better".
sgraing1
sgraing1
451xx
I worked on the antenna match this am and once I was satisfied I called out on channel 38 lower side band and made a contact with someone in Mississippi. Working as planned.
