- Ron
- Jul 22, 2020
- 23
- 216
- 310
- Pittsburgh
- 2021 Bronco Wildtrak
- Wildtrak
I just purchased a set of Mickey Thompson Baja Boss A/T 35X12.50R17, load range D. Any idea what a good tire pressure is for these? I was doing the chalk test. I drove around to heat up the tires. Started at 41 lbs warm and kept going down 2-3 psi at a time. When I got to 30 psi all around, I stopped because that seems pretty low. The cold pressure is going to be about 28 psi. Even at that low a pressure, there is still a half inch on the sides of the front tires where the chalk doesn't come off and an inch on the sides of the back that doesn't come off. Seems like going lower would be dangerous on the highway. I'm concerned about them being at 28 psi cold now. Any suggestions?
