- Matt
- May 23, 2022
- 3
- 64
- 65
- Houston TX
- 2022 Ford Bronco
- Big Bend
Thanks man! I'll buy some mosquito netting and glue an extra layer onto the gutter guard!They definitely help if camping inside your rig. Without some windows being open the humidity level will suck. You’ll freeze more when it’s cold and sweat more when it’s hot. Good airflow helps with that. These with keep out mosquitoes as mentioned - but if you have no-see-ums in your area there’s no guarantee. You could double-up the mesh to help.
no need to change anything. They work. Be careful using any heat source for any reason near them - they’ll warp easily. I would imagine you could somehow add a bit of a coat-hanger frame around the perimeter (on the outside obviously) to give it better rigidity - but I don’t use them enough for it to matter.
Good luck with your project and have fun camping!
