- Alex
- Jul 23, 2020
- 1
- 22
- 105
- Amarillo Texas
- 2012 Ram 1500
- Wildtrak
- #46
By all means, improve it. ThanksYou can use this under the Windows Subsystem for Linux using Ubuntu, Kali or Debian. If you use Windows to download the file, copy it and then dos2unix to convert the file properly (otherwise it won't run).
sudo apt install dos2unix
cp /mnt/c/Users/USERNAME/Downloads/bronco.txt ./bronco.sh
dos2unix bronco.sh
chmod +x bronco.sh
./bronco.sh
..for anyone running Windows 10. Replace USERNAME with your current Windows username (just type echo %USERNAME% at a command prompt to find it if you don't know). Just grab the WSL for the Microsoft store and setup the environment and you should be good to go.
If it's okay with the OP @Airforcetxn I might modify it with some user output so people know it is actually running and the last time check, etc.
