popo_patty
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
OP if you do end up letting your buddy weld it up, be careful if welding on your car. Even disconnecting the battery, a welder can still fry electrical components on modern vehicles.
Need to get the ground on the welder very close to the work area.
One of the guys I work with fried some components on his GMC recently when he was doing his exhaust and learned the hard way.
Good looking out! This guy is an expert welder and has been in off-road fab for 10+ years. We disconnect the battery and do nothing but the best ground lines to avoid frying a computer
NorthShoreBronco
Steph
Canada
www.youtube.com
21 Badlands 2D, 22 BD 4 Door
OH NO.... I better check my crack. will let you know.
popo_patty
popo_patty
Caleb
Sacramento
Barnes makes some good stuff but it doesn't look like they offer the rear UCA top side bracket, just the axle side. Maybe after this discovery one will soon be in the works.
I already reached out and am waiting! So far it’s been 4 broncos that I have found cracked.
popo_patty
popo_patty
Caleb
Sacramento
Flashbacks to being in the bad valve window :oops:
'21 SAS BL - Oct '21 build - No box but no crack....yet. Plenty of trails including Rubicon.
You have rust forming where the cracks form
PWillette
Parrie
Maine
Fly by Nite
Walt
Pa
The rust may be signs of the coating starting to fail due to flexing. Cracks may develop later.
TeocaliMG
Plymouth Michigan
www.brokeninnovation.com
So this Bronco has the worst that I’ve ever seen. It’s a first run of the 21, V6 Badlands from dirt mountain. The bracket was MESSED up. It was rewelded by the owner and then those broke as well. He is currently up in it, welding it again.
A while back there was a thread on broken axles and I was theorizing that due to the geometry, the lack of compliance (in tension/compression) in aftermarket arms may lead to binding. I removed/corrected my theory when others pointed out they were able to fully articulate practically by hand which would mean no binding. I also figured the geometry is too complex to simplify in just a 2D sketch.
These cracks have me thinking again. Especially if it seems to be limited to aftermarket arms. The image above is one such example of one of the more rigid options out there.
popo_patty
popo_patty
Caleb
Sacramento
It is a theory I am considering as well! Thankfully, it seems that for most, Ford has gone to the boxed design which is not cracking. Why some have this open design… I have no clue but I want to figure out a way to box it in
akturbo
Seattle Eastside
'21 Bronco, 3500HD Chevy, Rav4Prime, Turbo Skidoo
2021, Badlands SAS, 2.7L, MetalCloak arms. Not a fan of the rust marks on the welds, I don't see cracks. Have cracks been found on the passenger side?
Ford Bronco Check this NOW if you have a 2021 Bronco -- cracks on rear control arm upper brackets IMG_13683
popo_patty
popo_patty
Caleb
Sacramento
Yes, mine are cracked over there as well.
As far as the pic. Look closely but I spy crack. That’s exactly how mine started
broadicustomworks
Hanging Rock, North Carolina
I'm thinking order the simple parts nut plate/captive nut present on the capped version and use some 1/4", box that puppy in and use the new captive nut insert....basically mimicking what Ford did on the revision but in a bit thicker metal.
Plus most of my scrap I can get readily is all 1/4" and thicker, so it's an easy decision for me.
UncleBuck
Washington
2011 Ranger XLT 4.0L - 4x4
Ford Bronco Check this NOW if you have a 2021 Bronco -- cracks on rear control arm upper brackets IMG_6235
‘21 badlands 2.7, Sas, Tow Package. Built on 12/7/21 and delivered on 12/23/21.
Looks boxed and not rusty. Doesn’t look cracked.
akturbo
Seattle Eastside
Sh!t, I only had a few minutes to look, I'll get back under there later (not in street clothes) for a closer look.
GreyZ
Gulf South Louisiana
Turbo 350z, Bronco Badlands, Xterra
Have any seen cracks with oem Upper and Lower control arms. These cracks don't seem like they would occur with forward and aft movement. Seem to be caused by seperation/torsion of the two mount faces which would occur with increased articulation.
Solid sphericals/johnny joints at the rear control arms would allow for undampened flex right to the max articulation and could allow for impact loading of those joints in rotation which would put insane seperation/twisting forces on those mounts.
Either way, if you go to reweld it I would make sure to put a plate on thhe bottom to atleast partially box it.
