Hello everyone, it’s day three of owning my bronco and I figured I’d share my first modification.
I’ll go through this back to front
I started with weBoost Drive Reach OTR (https://a.co/d/9f81IPu) and mounted it to the Hooke Road Wrangler JL CB Antenna bracket (https://a.co/d/ioQOszq). The bracket mounts to the bronco just like a jeep on pax side of the tire carrier. I then fed the antenna cable through the cabin vents and attached it to the existing wiring under the black panel on the swing gate.
From there I popped the pax side rear panel loose and fed the cable up to above the wheel well.
I mounted the weboost box with hook and loop to the top of the pocket (where lux speaker would be) between the plastic interior panel and the body panel.
To power the weboost I hooked up to the pre ran white/orange power wire in the rear and then connected the white/orange to the brown wire underneath the glove box. The brown wire then was connected to the yellow/orange wire under the hood so that switch 6 would power on the weboost.
The interior antenna I ran down the door to the B pillar, under the seat rails and into the center console where I mounted the antenna with the included double sided adhesive.
The only test of the weBoost that I’ve done so far was sitting in the driveway and it went from 1 bar 5g to 3 bars 5g
I’m by no means an expert at this, in fact it’s the first time I’ve ever installed anything like this so go easy on me haha
