Color Matched Hardtop vs Stock Carbonized Gray
BroncoJay
Iowa
Tacoma
if ford plays bait & switch, they'll lose me.
I can’t figure out why they aren’t set on what options go with what trims. Strange to me that things have changed from the initial launch for options
2Jeeps&PatriotX1
Denver, CO
2Jeeps&PatriotX1
Denver, CO
I'm not an expert here as I only detailed and restored cars for a decade, and that devolved into boutique detailing for select clients long ago (customers are the worst!)
But your problem is that you're using a garbage product and wondering why it doesn't work. At least you didn't say "Back to black", which is possibly the only shi%%&^# product you could possibly be using to restore or protect black plastics.
If you want to actually re-finish black plastics, may I suggest Solution Finish. This stuff actually penetrates the plastic and will restore it's color. I've even used this without any surface prep work on a neighbor's stupid JEEP with fender plastics that had turned to a white powder appearance. Penetrated perfectly on the first pass and they still look good 5 years later.
Solution Finish: Black plastic and vinyl restorer
Treated/untreated
Before/after
I have been quite upset about the only hard top on the 2-doors being grey. So if I have to get stuck with that then i'll be trying the new Solution Finish for grey plastics.
Solution Finish: Grey plastic restorer
Also, using a UV protectant such as 303 aerospace protectant will go a long way in preventing the fading from starting.
FYI: The small, $15 bottle of Solution Finish Black should be enough to do about 20 Jeeps, restoring every single piece of faded black plastic and fender on every single one of them. That stuff just keeps spreading like a champ!
I love me some aerosoace 303...use it on my jeep soft top and all my plastic door panels in the jeep and truck. Even use it on my jeep’s rollbar padding.
SeventyOne
San Francisco
1971 Bronco, 2014 Grand Cherokee
Treated/untreated
Ford Bronco Color Matched Hardtop vs Stock Carbonized Gray simp
Before/after
Just ordered the solution finish. thanks the the reco, Rick
JDisFlip
Las Vegas
Waiting
Has anyone gauged what colors will
Work best with the (uugh) grey HT?
I liked the cactus grey and carbonized grey, seems to blend in better..
Thoughts?
I've only thought of the colors that the base can get (since I'm getting a base trim 2 door), I've thought in the way of what would play ball with the MIC top, and what would dominate it.
I feel eventhough the top is a small part of the vehicle if you are looking at it in comparison to the body color and rim color, the grey coloring of the MIC top is distracting enough that it grips my attention away initially from any other vehicle part (... or is this just me ? ).
I think as a color to team up, or work together with the MIC top, Iconic silver (to me) looks like a decent blend.
I like some of the pics I've seen, and the shiny metal look it has.
Some dominating colors, I think of the darker colors like, Antimatter blue, Carbonized grey, and if you like-Shadow black (we've seen many pics of this combo and it works for me as a fall back ... that is if you like the color for your vehicle- some don't).
... I would hope to see more real life pics (or in person) the colors I have chosen on real production vehicles and less renders so we can all pick what colors we would like.
:cool:(y)
Deleted member 2346
Guest
Yeah the grey top looks silly when the handles and flares are black. And a gloss black looks just as silly. Ford trying to be different. Don’t do it Ford. Lol
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Probably make it black? Which I'm good with. I'm using mine for the plastic on my 2014 WK2. Started fading around 2018.
If so that’s an even easier solution than rhino lining it Matte black. DIY, cheap and won’t take more than an afternoon
Edit: @BroncoGuy would this work on the type of material used for the MIC top? Could it theoretically make a grey top appear black?
SeventyOne
San Francisco
Ford Bronco Color Matched Hardtop vs Stock Carbonized Gray IMG_20200904_104056
This stuff seems to penetrate well. I think if you removed any sealers/wax from the MIC gray top you could probably get it this black
Norm A.
Norman
I might be in the minority but I like the MIC top in Gray, BUT I would prefer the MIC in White?
