Between Sync and Android Auto there is definitely some sort of night mode on my FiST.Or night mode. Our rav4 does.
If it's like most Fords, it will have day, night and auto switch settings as well as brightness control.Most screen are smart enough to change to a black background at night and reduce brightness. A bigger screen makes the nav and off-road maps easier to see. And may allow more customizable screen options to fit more info on it.
Since my budget is 40k one thousand more or less, I can’t get badlands; my badlands build is at 48500, so since your budget is badlands range, get the badlands for me pls?I have stuck with the Badlands since I could not get in on the First Edition. Also, since the MV seats are only available in either the Badlands or Black Diamond pretty much has limited my model selection.
Here are my reasons:
1. Black Diamond has MV grey/black seats and Badlands are black. I figure I would roast less. Where are all grey MV seats Ford?
2. Black Diamond does not have the swaybar disconnect; I like to keep my suspension simple stupid. I feel there will be something better after market.
Cons:
1. I wanted the 12" LED screen and will have to settle with the smaller screen
On a separate note and some may not agree I think the Black Diamond stock wheels are the best across all Bronco wheel options. I will be going Sasquatch so I will be forced to go aftermarket.
The wife and kids want the bigger screen. Happy wife happy life.What do you see as the advantage of the 12"screen?
the optional aluminum ones are clean thoBlack steelies, I have to say negative on those.
Yep And to Quote Foxworthy "And if she ain't happy long enough your unhappy with 1/2 your stuff"The wife and kids want the bigger screen. Happy wife happy life.
Honestly, I would have stuck with the Badlands. Who wants black seats on a topless vehicle? I live in the high desert.If they gave the option of MGV interior on Black Diamond on Badlands which would you pick?
When you go to the High package you get the 360 view cameras so that would look better on the 12" screen . I'm sure that's why Ford put the two together .What do you see as the advantage of the 12"screen?
This is making heads spin.When you go to the High package you get the 360 view cameras so that would look better on the 12" screen . I'm sure that's why Ford put the two together .
I agree you get most of everything with the Squatched BD but you still miss out on the Signature headlights , the LED rears , the configurable high level instrument panel , Baja mode and you're stuck with the bright blue interior trim nd stitching .
Agreed I’m hoping they make it an optionHonestly, I would have stuck with the Badlands. Who wants black seats on a topless vehicle? I live in the high desert.
Me personally I want the 12" because my eyes aren't what they used to be, so I think in my case bigger is better?What do you see as the advantage of the 12"screen?
