Coming Soon... License Plate Relocation Bracket
StuRox
Stu
Chicago
Honda
What do you need rubber washers for? We include hardware for the license plate if that's what you mean (to mount the license plate to the bracket)
I mean attaching your bracket to the steel bumper. I wanted a buffer so bumper does not scratch/rust when attaching it to bumper.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
No we didn't plan to include anything for that. We don't use anything that rusts. The brackets are made out of aluminum... not only that but we powder coat them. If you have concerns over your factory bumper rusting you can install a pad on there but we don't feel it's necessary.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Great! Please post detailed pics showing what bumper looks like from underneath, along with what is removed and how it is attached. I am hoping you include rubber washers, etc.?
Some prototype pics (it's a 3D printed bracket for now, as we make some final adjustments, as I want to give folks the option to have it sit flush against the bumper OR allow them to have it sit straight on). You can see my other license plate bracket installed as well
Ford Bronco Coming Soon... License Plate Relocation Bracket 1633445497609
Ford Bronco Coming Soon... License Plate Relocation Bracket 1633445512471
Ford Bronco Coming Soon... License Plate Relocation Bracket 1633445525086
Once I install our Baja Designs XL Linkable Kit on the bumper, we'll do some more test fitting. We're designing it to ensure it works with an aftermarket fog light kit AND bumper mounted light bar kit.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
So while I finished the prototype tonight on this bracket, it's sadly not going to work 100% because of the front sensors. The front sensor thinks something is there (and it's not wrong). It sits nice and straight without blocking the fog opening but the sensor detects it. Ohh well. We wanted to have a 2nd option but this might not work as planned. It'll block the fogs if we lower it and where it sits now, the sensor picks up on it.
I could go off towards the center more and I may continue development on this later, but I plant to install a light bar on the bumper, so I want to make sure the plate doesn't block the light bar either.
Ohh how fun prototyping is!
Ford Bronco Coming Soon... License Plate Relocation Bracket 1633482714438
Ford Bronco Coming Soon... License Plate Relocation Bracket 1633482734989
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
I’m bummed you changed the location up so high. I prefer the previous design. Did any of those get made? Or no?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Which previous design? We have 2 designs in 2 different threads (I should see if I can combine them).
THIS one (the one attached to center of bumper) is still going into production after the recent changes (we made changes from this photo based on feedback from the public). As I said we made some changes where we made the back-plate smaller so the license plate hides it, and made it so you only need 2 bolts to secure it (easier to remove it at a trail head)
Ford Bronco Coming Soon... License Plate Relocation Bracket 1633483417005
72BroncoSand
PNW
Am I mistaken? i am remembering same off-set but top of plate flush with top of mod bumper.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
72BroncoSand
PNW
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes, that’s the one. I preordered this one.
Yeah we're a dealer for BuiltRight so we sell this one on the site. It does block your fog lights though, but if you don't plan to run fogs no problem there
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
Here's some photos I took with our Triple Fog Light Kit. Keep in mind this again was a prototype bracket for the fogs, so the lights don't go all the way to the outer edge (the final design does, again because of 3D printing we only print part of the bracket to save time, which is why the lights are all bunched up together)
Ford Bronco Coming Soon... License Plate Relocation Bracket 1633491697060
I’m more interested in this configuration of lights. Backwards from other pictures y’all have posted with the small light on the inside. It doesn’t look like the outside squadron is really blocked much at all.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
What you are seeing are our KR Off-Road brackets, with Baja Designs (and in some photos Diode Dymamics) lights mounted up. We have an in-house brand called KR Off-Road where we manufacture mounting brackets for lights (and some other doodads we find are necessary). Lifetime warranty, made in the USA, good stuff.
So those are available here actually: https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/
Our brackets are VERY popular in the Raptor world, and now that the Broncos are starting to hit the market, we anticipate our brackets will be popular here. They allow you to mount pretty much any light up to them, and we don't force you into using certain lights. You can select any combination of sizes you want really. Here are some examples:
Ford Bronco Coming Soon... License Plate Relocation Bracket Baja Designs 1
Ford Bronco Coming Soon... License Plate Relocation Bracket Lights1
Ford Bronco Coming Soon... License Plate Relocation Bracket Lights2
Ford Bronco Coming Soon... License Plate Relocation Bracket Lights3
Ford Bronco Coming Soon... License Plate Relocation Bracket Diode Dynamics 1
Ford Bronco Coming Soon... License Plate Relocation Bracket Diode Dynamics 2
4avor8ntfair
Houston, TX
Yes, thanks! I’ve seen those brackets/packages. I just hadn’t seen any showing the S2’s on the inside of the group, and it caught my eye. It’s usually on the outside, like it is in the pics you just sent
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yeah that's why we developed these brackets. We wanted more options as to which lights and how you set them up. So you can pretty much design any fog kit you want.
Jbronc74
Julian
Los angles
74 bronco , 2018 expedition, 2021 broncoFE
try to bend it flush with the skid plate and see if the sensor still reads it.. I think it will be plenty readable with that angle....and all you'll need to do is bend them all...then make one with a bracket like a 74 tailgate plate has.. so you can flip it up if the police has an issue with it bent back....
