I"m going with bugs, B&P is not refined yet.As of right now you can build a 2dr Badlands with squatch package with roof rails and sound deadening and 2.7L. If you try to add rails and deadening to 4 dr it removes squatch and 2.7L
Thnanks. i moved my comments to there!!There's already a thread going...
https://www.bronco6g.com/forum/thre...issues-with-build-and-price-application.7297/
Jeez, a Rubik’s cube of incompatible options. Did you try it on more than one trim? Thanks!As of right now you can build a 2dr Badlands with squatch package with roof rails and sound deadening and 2.7L. If you try to add rails and deadening to 4 dr it removes squatch and 2.7L
Product launches with mistakes should be the exception, not the expectation.There seem to be lots of bugs in the system.
I am trying to keep mine under $45k. I started with a Base model, 4 door, Hard top, and Sasquatch.
Bugs I see:
1. I can't get the roof rails with the Sasquatch package with 4 door. i have seen lots of pre-production Broncos with both.
2. No manual transmission on the Base model or with Sasquatch. not for me anyway, but...
3. No towing on base. Really?
4. More paint options. Maybe 2022 will allow for base with more. Cactus Gray or Area 51. I do not want to wait, but it would give me the opportunity to save more.
5. Accessories. I am sure they are going to add more as the days pass. Some will be MUCH cheaper aftermarket. (Example - tow hitch for a new Ranger which has the same frame as Bronco is $250. from Reese including the plug.) Not paying double that just to get someone at Ford to install and warranty.
I am glad they are up and running. Bugs and all. If people understood programming, they would realize that even being a HUGE Corp like Ford, there are going to be bugs to work out. Kudos to the engineering and IT teams at FOMOCO for what we have so far!!
Agreed. Input from the consumer may yield quicker fixes - that’s the spirit of intent for this thread.Product launches with mistakes should be the exception, not the expectation.
I was REALLY hoping that nobody would post this and that it would slip though the cracks... but here we are...1. Adding the mid package automatically gives you auto for free.
CONFIRMED - that I totally agree ?can we please stop using CONFIRMED in the title of every fucking thread.
Plus we already have this thread.
The Bronco's "platform" will be shared with the upcoming 2022 Ranger. It does not have the same frame as the current Ranger, and it will not have the same frame as the new Ranger, the Ranger's wheelbase is 10" longer than the longest Bronco.(Example - tow hitch for a new Ranger which has the same frame as Bronco is $250. from Reese including the plug.) Not paying double that just to get someone at Ford to install and warranty.
guess its a bug then, because it said "removes mid package". I'm guessing we got the Beta release.I am able to add both mid and Sas to a Black Diamond.
