Confused about the high towing rating on new Rapter vs Bronco
vrtical
Doug
GSMNP, TN
Fords
some of you keep looking at it wrong and its not parts used. Bronco classification and its dry weight are the real issue. towing something will add to your payload weight by subtraction. Rule of thumb is 10% so the bronco is maxed at 350lbs towing 3500lbs that comes off your payload allowance per vehicle specification. if you have 1000lb payload max, you just used up a big chunk of that. A 5000lb trailer limit is now 500lbs.
Laminar
Iowa
Cougar
So what gives with the Bronco tow weight restriction and the Rapter gets a tow weight improvement over last year?
The old Raptor was rated to tow 8000lbs. The regular EcoBoost F-150 SuperCrew could tow 12,500lbs. So maybe the new one is a little better than the old one but it's still a far cry behind what the chassis can do with a firm suspension.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
And is unibody vs body on frame
Hmmmm... wonder what it is then? Defender is basically a unibody... I would think a truck chassis would be better for towing.
it's a paperwork thing. they see the wrangler as the only target and don't want stellanis to claim it's not apples to apples comparison.
should be interesting to see how FORD addresses the roof rack issue for MY22
Silver-Bolt
Bill
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
The short wheel base and top heavy center of gravity on the Bronco is the reason. The Bronco has significantly more weight above the center of gravity than the Ranger does. It has nothing to do with frame strength. Everything to do with being a top heavy SUV.
Cookieck
Georgia, USA
Camaro SS, Indian Chief Vintage, Yamaha Fz1, Honda Shadow, etc
The broncos is most likely just an artificial limit to keep it where Ford wants it. Otherwise there would be different tow caps between wheelbases and engines and gearing and tires that all change pretty significantly on the bronco. But there’s just a single tow cap across the board. Like those saying it’s different from the ranger because of wheelbase, there’s a larger wheelbase change from 2 door bronco to 4 door bronco than from 4 door to ranger(16in from 2dr to 4dr, 10in from 4dr to ranger). If wheelbase alone gave the ranger double the tow cap then why’s the 2dr same as the 4dr? So regardless of what else you compare it to and what reasons are given either way, comparing it to itself and the changes between options shows it’s most likely an artificial limit at some point.
85_Ranger4x4
Iowa
1985 Ford Ranger
D44 on Wrangler is only on the Rubicon, or used to be. But I believe all Wranglers have the same 3,500 lb limit. I could be wrong though.
Yeah, it's standard on the ranger and Bronco though.
Hey19
JJ
Bethlehem
Lakelife36
Ben
Interior of BC
As per SAE J2807 the stated tow capacity is based on having 300lbs of payload onboard (TWR=GCWR-curb weight-150lb driver-150lb passenger), so that may keep things this low in an FE (which you can't even get the 3500lb tow package in) but certainly not in a BB for example.
Johnnyd
Johnny
Chilliwack
Bronco Outer Banks
Hey guys I'm getting the 4 door outerbanks with the 2.7. I have a travel trailer that is 3400lbs dry weight and once packed up at least 4500. Is there anyway to get this thing to tow It with adding some things?
6GSooner
F250
Nope.
Lakelife36
Ben
Interior of BC
I'm hoping that the answer is to wait a year or two for the lower trim non-Sasquatch 4-doors to get their own GCWR and a Class III reciever.
Rivers90
Ben
california
xterra mx5
The rear receiver is a recovery point to me.
100% my current 4wd vehicle has used it's receiver as a recovery point and to mount a bike rack.
That is all my Bronco will need to do too.
It is nice to have a center recovery point to get a straight pull.
The Pope
The more correct answer would be..... We don't know yet, as it will take some time for the aftermarket to develop something. Granted, anything that will increase the safe towing range for the Bronco, will also reduce the Off-Road abilities.
I hope that FoMoCo will offer a True Heavy Duty Tow Package which would give the 2D closer to 4000lbs & the 4D closer to 5000lbs towing capacities.
