Exactly. Should be part of cargo area. Donāt have much use for 12v in that space.
Just watch the power rating - only 100W on that example is fine for your mobile devices, but not enough power to even light an old incandescent bulb.Exactly. Should be part of cargo area. Donāt have much use for 12v in that space.
Just checked the User Manual - 20 amp and 240 watts max.Exactly. Should be part of cargo area. Donāt have much use for 12v in that space.
Sorry what is a pure sine wave ? Is the is not as simple as plug and play ?Can it be converted to a 110v outlet? Is there an adapter for that ?
If you do opt for an inverter consider the devices you're going to power up.
The inverter should be a pure sine wave inverter if you do not want to damage sensitive electrical components.
thanks....this doesn't sounds as simple as I thought it would beSorry what is a pure sine wave ? Is the is not as simple as plug and play ?
So I can power tools, fridge, etc ??
I would recommend watching a few YT vids before leaping into an inverter.
Some inverters are described as "dirty" due to the lack of a "pure" sine wave. The pure sine produces electricity comparable to the power one receives from the household utility power supply.
Once you're properly set up power tools and fridge will work fine.
what do you recommend......I just have no use for the 12v lighter.....but I would for 110V Outletare not only converting 12V to 110v you are also converting DC to AC current, so it is a tricky but not rocket science. There are many good converters out there but there is also crap like that āAmazonā lighter plug thing
