Could Sasquatch "high clearance suspension" mean a 2 inch lift?
BroncoFanBoy
Brandon
Az
Nissan
The Sasquatch package says that it comes with a high-clearance suspension. any one have details on exactly what that means?
I know there are pics of 2-inch lifted bronco with 37s... think the Sasquatch comes with an extra 2 inch lift?
rtaylor
R
ID
19Raptor, 22Bronco
Sasquatch has been reported as 1.2".
  • 1.2-inch Suspension Lift-Kit
  • Higher-Mounted Fender Flares
  • 17-inch Beadlock-Compatible Wheels
  • 35-inch Mud-Terrain Tires
  • Front and Rear Locking Axles
  • Heavy-Duty Position-Sensitive Bilstein Shocks
  • Shorter Final Drive Ratio (4.7)
Other reference points:
The height of BigBend w/32's is 72.9" and Badlands w/33" is 73.9". Tires are at most 0.5", so that would only be at least 0.5" lift for Badlands/33 HOSS w/Bilstein.
The height of BigBend w/32's is 72.9" and WildTrak w/35" is 75.3". Tires are at most 1.5", so that would be at least 0.9" lift for WildTrak. However, Wildtrak's baja-type suspension may be completely different.
BroncoFanBoy
BroncoFanBoy
Brandon
Az
Nissan
For someone who will drive 95% on the streets and still wants a badass looking bronco... is Sasquatch too much? Would the 95% driving experience on roads be significantly improved by only going with 33s?
Louisiana
15 F150 4X4, 16 Mercedes Benz S550
Good question. I'm wondering the same thing!
Raptor911
Raptor911
Broadlands, VA
Can we assume that the Sasquatch package will give any trim a 1.2" lift. If yes then the WildTrak would get a 1.2 inch lift correct?
BroncoFanBoy
BroncoFanBoy
Brandon
Az
Nissan
wildtrak comes with the Sasquatch as standard equipment, so I assume any measurements on WT include the sassy
Raptor911
Raptor911
Broadlands, VA
The Bronco looks badass with 35" tires.
My daily is a Raptor with 35s and Ford does an incredible job to make 35 feel great on the road. Most trucks that run 35 will tram like crazy but I never get that sensation from the Raptor.
If you can swing it I would def get 35 on the bronco. 35s will roll over potholes like they are not there
BadSquatch21
PA
Land Rover and Porsches; '22 Mansquatch
Considering the Badlands has the same suspension as the Sasquatch, anyone have any idea from pictures how they are getting the extra 1.2" on the Sas? If there really isn't going to be a manual Sas my plan is to just add the wheels and flares to a Badlands. Just curious how easy the lift will be if needed for the 35's.
The closer I look now at the height difference between Badlands w/33 and Wildtrak w/35's, it looks like only a 0.4" difference if they were on the same tire. I wonder if a Badlands can fit 35's stock.
jtzako
Xterra Pro4x
I feel like having to get 35s to get to 11.5 inches of ground clearance sounds wrong. Do we know if that quoted 11.5 is really with the sasquatch package or is that the height w/ 33s?
BroncoFanBoy
BroncoFanBoy
Brandon
Az
Nissan
I assume you need Sasq... so 33 to 35 will add an inch of ground clearance, right? Why would they quote stats from a middle size tires available on it?
BadSquatch21
PA
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Ford Bronco Could Sasquatch "high clearance suspension" mean a 2 inch lift? 1595325397601
Now, take a good look at that. You ever see so much stuff lower than the rear diff on an off road vehicle? Those shock mounts are why the squatch has such surprising low amount of clearance.
That 8.4 inches for I guess the base isn't too good. There's quite a few SUVs that will beat that.
jtzako
Xterra Pro4x
That was my complaint on the bronco. How can a relatively large SUV have such low ground clearance on 35s? The xterra pro4x has 9.5" clearance on 32s and stock suspension for comparison.
LuckyDevil
Lucky
Knoxville IOWA
Twin Turbo Black Label MKX, Harley Davidson StreetBob
So it doesn't handle like :poop:
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Except a Badlands. In that case about a .6" suspension lift of some type, plus the bigger tire.
