Lewisj41
Jesse
Maryland
2017 Tacoma
SilverII
DFW
Imagine the work the brakes have to do to stop all that torque.... better have some good brakes
vrewald14
Vince
Iowa
03 Ford Excursion, 79 Ford Bronco, 04 Toyota Camry
Really nice to see a post involving factual math and data instead of everyone's opinion :LOL:
This 95:1 crawl ratio is truly impressive.
SilverII
DFW
Why would you be braking against your engine torque? Brakes act at the wheels, they operate independently of any gearing.
The brakes have to stop 40K NM of wheel torque
brokentwig
Andrew
Colorado Springs
2007 Avalanche
He is modelling the Bronco with just 1 wheel on the ground, using a max of 5000 lb-ft of torque. I would guess in granny gear, you would have the sway bar disconnected and both lockers engaged, so you would be able to use a lot more of the available torque.
Gamecock
That is a great video...makes the manual much more appealing, as you wouldn't have to slip the clutch near as much as in anything else, making it much more driveable and forgiving when crawling.
BroAD
Adam
Illinois
2012 Ford F-150
This YouTube channel is full of great information. I am brand new to the off-road community and really needed some help understanding the difference between HP and torque as well as drive ratios. Any questions you may have about the concept, this guy has a video for it.
Great Stuff...
