NaturalFlorida
Dale
Vero Beach
1985 4Runner SR-5 / 7" lift / 5.29 Gears / Lockers
A few questions,
Compatible with the Harbor Freight APEX Badland 12k Winch and it's Fairlead, same basic design as the Warn EON 12k.
Compatibility with OEM "Full Bash Plates"
Option to assimilate the OEM Fog Light circuit to Compatible Fog Lights IN the face of the Bumper.
OEM Parking Sensor Compatibility
Flat Tow / Recovery Shackle Plates, Compatible with Common Tow Bar adapters
Thanks for your comments
I look forward to hearing from you about updates
Advertisement
LSOR
Luke
Carlisle, IA
The Apex is simply to wide.
Yes, this does remove the front bash plate though and replaces with a much beffier one.
We are working on that. the factory fog light assembly is quite large behind the bumper. so we are trying to figure out a solution.
Yes, that is available, you just select that when checking out.
The recovery points are strong enough. I will look into this further. I have never flat towed so Im not very familair.
TexAZ
AZ
F-150
@LSOR possible to countersink those bolts on the skid plate? Square holes for carriage bolts? Afraid those hex heads wouldn’t last long on the rocks over here in the west.
LSOR
Luke
Carlisle, IA
we find it easier to cut and replace these grade 8 bolts if they get destroyed rather then finding specialty counter sink hardware. If that gets Messed up it’s typically not as easy to remove and replace
4avor8ntfair
Houston, TX
Explorer
Bird Dog Overland
Jody
Chicago, IL
www.youtube.com
2018 Toyota 4Runner TRD Off Road
I know information is still not widely available, but I'd love to have this list be incorperated into a spread sheet and also include approach angles (for Stock and Sasquatch models) for each as well as weight. The top line could include the stock information for reference.
AZBronco73
AZ
2015 Dodge Durango
Is the forward camera blocked by the winch with the offset side mounted solenoid like the on ein your photos? And for the ACC, is it being relocated to the bronco grill with your bumper?
LSOR
Luke
Carlisle, IA
I will have a camera answer this week. ACC is below the winch.
jaeggernaut
Jay
Toronto
2001 BMW Z3 M Coupe
if you made a package to just move the camera, I’m sure it would sell out.
Looking forward to seeing what you find out with your existing bumper. đź‘Ť
Updating with some info on the Lifestyle Offroad Bumper.
The factory Mod bumper weighs 79 LBS.
The Lifestyle Offroad Bumper is 80LBS, The skid plate is an additional 39LBS then the weight of your winch. Overall you will likely be under 100lbs over stock weight if using a winch with a synthetic cable.
The bumper has a very High approach angle while keeping the winch low. It is not as flashy as others, but built for the Offroad enthusiast that is going to wheel and use their bronco in extreme situations.
Forward facing sensors and ACC are also now available.
Nellman
Josh
Northern California unfortunately
2007 Toyota Tundra
I have reached out to Bay Area Metal Fabrication and am going to go with their bumper. It does block some of the front camera but is minimal. This is the image that Jerry at BAMF sent me.
I can live with this minimal camera obstruction as it is directly in front of vehicle. I am sharing to help everyone better gain information on the options available. I will share more once I get the bumper and get it installed.
@Shinoko Thank you for putting this together it was a huge help.
Tilzbow
NV
GM Sierra Diesel Pick Up
I’m about 95% set on the LOD bumper. It’s checks all the boxes:
1) Flat towing compatible. Seems like the best of all since the recover/tow brackets appear extremely robust and attach directly to the frame as far as I can tell.
2) Appears as if the skid plate vents will allow sufficient airflow to the intercooler on the 2.7.
3) Accommodates parking sensors. Not a big deal for me but I ordered the high package so my rig will have them.
4) Appears fairly compact and doesn’t appear that it’ll decrease approach angle too much.
5) Pockets for lights
6) Not sure about the camera but it doesn’t seem that it’ll block that too bad. Need @LOD Offroad to check on this.
7) Reasonably priced and not extremely heavy if pricing and weight on their Jeep bumpers are an accurate estimation.
8) Not sure about ACC for those who will be getting that. It’s not something I ordered or desire.
https://www.bronco6g.com/forum/threads/lod-offroad-is-in-the-house.25666/
CptSamFalcon
Sam
Seattle, WA
2021 Bronco 4dr BD, 2021 Kawasaki KLX300
Adding this to the mix. My current plan is to get the RC hidden winch kit, and one of these JCR off-road bull bars for the extra protection. That’s a cheap enough solution that I won’t be out too much $ if there’s a future bumper that I switch to.
https://www.bronco6g.com/forum/threads/jcroffroad’s-bolt-on-steel-bumper-parts-hoops-more.29264/
JCR is working on a winch plate that looks good to me. But I do not have a front camera on my Black Diamond (I think?... dont have it yet)
BLMike
N. California
Jeep Ultimate Wrangler and two other normal cars
What about the ACC? I see BAMF has a bracket but it sounds like it raises above the bumper so it is in front of the grill. Don't know how that looks.
Nellman
Josh
2007 Toyota Tundra
Yes the bracket is the change. it raises the acc above the bumper in front of the grill.
BLMike
N. California
Yes the bracket is the change. it raises the acc above the bumper but still behind the grill.
Description says in front. "...ACC (adaptive cruse control) We have come up with a bracket to relocates it in front of the grille to allow the system to be used with a winch."
Advertisement
Advertisement
