- Eric
- Jul 22, 2020
- 14
- 1,414
- 3,953
- Fidalgo Island, WA
- 23, 69 Bronco
- Base
I got a $10 adapter cable to tie my Prodigy brake controller to the customer access connector above the gas pedal. I'll either tap into the blue output wire at that connector or add a pin to grab it where it dead ends over the front left tire then run it to the 7-pin.EDIT: I found some of the drawings on here, so tell me if I am getting this:
From my brake controller , I can tie into the customer access harness (c2608) to get my signal (Is it wire 14 or 12?), and then just run the blue brake output back to the 7 pin harness like normal.
Correct?
It's fully potted so just keep it away from heat. I put mine on top of the frame rail like the instructions show. The ground location is more likely to give you grief than the module location so I grounded mine behind the interior trim.Where is everyone stashing the module? Is that safe being open to the elements? It seems pretty well sealed - but, the last thing I want is electrical issues.
