JRBinMalibuCanyon
Malibu Canyon
2006 Jeep Wrangler Rubicon
Hey guys. Wanted to share pics of my build. 1-of-1 custom heritage Cactus Gray Wildtrak developed in partnership with Avio Coachcraft. When I first saw the new Bronco I was dead set on getting a classic white top/white grille combo. With that unavailable until the then-rumored Heritage Edition came out, I decided to stick with my 2022 2-door Cactus Gray Wildtrak, and create exactly what I wanted out of a vintage-style modern Bronco. Here’s a quick overview of the build, and a bunch of pics. Would be interested to know what you guys think, and especially how you think it compares to the official, forthcoming Heritage Edition.
Top: Wimbledon White with smooth surface (comprehensive surface prep and window removal/reseal coupled with glossy paint finish better than OEM quality).
Grille: Five-tone design based on Black Diamond grille modified to host Lux camera system and prepped smooth like the roof. Body color outer frame, Wimbledon White inner slatted section, gray pinstripe demarcating inner/outer sections, black center section, red lettering and white letter borders. StickerFab amber LED turn signal overlays (astonishingly factory-looking but removable if desired). Multiple clear coats and Xpel protection.
Fender flares: Prepped smooth and painted body color, with full Xpel protection (front side of rears are double-filmed for extra protection).
Wheels/tires: 5x Fifteen52 Analog HD 17 wheels prepped and painted Wimbledon White, with two-tone WW/black center caps evoking hubs. BFG All-Terrain T/A K02 with black lettering. Wheels/tires sized to match OEM Sasquatch.
Fender badging: OEM-licensed first-gen black chrome Bronco script with red Sport badge (because it looks great and they should've called the 2-door the Bronco Sport!).
Other mods: 1.5 inch front leveling kit (not pictured);Factory rock rails with removable iAG stirrups; 2x Baja Designs LP6 amber LEDs (~9K lumens each) on front bumper using Swarfworks mount and wired to first two Aux switches (low/high) with backlighting coupled to DRLs; 2x KC Flex Era 4 white LEDs (~9K lumens each) on A-pillars using Bad Ass Mounts swiveling mount system and wired to third Aux switch with backlighting also coupled to DRLs; Xpel paint protection film on grille, fender flares, hood, front fenders, doors and rear rockers; Ceramic coating over painted surfaces; iAG mudflaps; OEM tailgate table with molle bags; Mountains-to-Metal steel front door pockets with molle bags
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build ECA43E6F-0BC4-4D65-90F1-3DA6D5906ADD
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 88CF7D13-28BC-4F97-A0A9-FB3F93810DF8
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build E2421E9B-1B88-4495-8A71-FCEF37A15BF5
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 87F19C28-D378-491F-93FB-3B54DA312FF8
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build B5DDB5DA-01EA-465B-9119-1125AA8A068D
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 1D4D5F2C-856B-495C-9528-B012C42C5278
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build D29DB5A4-8DC6-4CFB-B410-7DC66C530DC7
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 938932F7-0FD3-4042-989E-04986D0E6632
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 5411CE28-ACB3-40D6-B4EF-08C62B4A378C
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build B40762B8-3547-48DB-B8DE-F2F99E301F5D
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 8AF06C52-76C2-48D7-9A21-4870FE6569BD
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 2C2D800B-0667-4D53-9EF1-05BC9679C98F
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 1C50DFF1-46DF-4A20-9C0F-71BB8749DE14
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build CF40C51C-2256-435F-87C1-CEAC20F1A050
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 1FE94F7F-4930-4140-969F-F301A1C14675
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 60AA98AC-7343-4FBF-96C6-E4DF179B6D30
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 1DFE4D3A-9C61-4CCA-89C5-E65FA650FF7A
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build F2F6FF37-0B48-4B31-80F9-B2F18DA8C92F
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 587F8D8B-B1B8-4868-97F8-9ED707B64FFB
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 2E5694FA-DCE2-487B-809A-854B1BBA138F
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 04EB3F0D-7515-44B5-B4ED-70E551CCF46E
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build E8D454A2-582A-4D23-9D30-9A5E55481863
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 0606F91F-076A-4DB0-BC57-892115812A36
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build 54FA66BF-05A9-4AC4-92CC-43C93D441F5A
MNbronco
RC
SE MN
2021 F150 Tremor, 2021 Bronco sport
well done, Looks great!
stickshifthappy
RVA
Ford Ranger, 65 Mustang
That's a walk off home run right there !!
Lowcountry Bronco
William
South Carolina Lowcountry
Looks great! Love the grille detail and that you went with WW on all the white bits. Can't wait until my standard HE shows up whenever because as you know, a Bronco is supposed to have a white top.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Killer job!
BAUS67
redneck
Central PA
Other mods: Factory rock rails with removable iAG stirrups; 2x Baja Designs LP6 amber LEDs (~9K lumens each) on front bumper using Swarfworks mount and wired to first two Aux switches (low/high) with backlighting coupled to DRLs; 2x KC Flex Era 4 white LEDs (~9K lumens each) on A-pillars using Bad Ass Mounts swiveling mount system and wired to third Aux switch with backlighting also coupled to DRLs; Xpel paint protection film on grille, fender flares, hood, front fenders, doors and rear rockers; Ceramic coating over painted surfaces; iAG mudflaps; OEM tailgate table with molle bags; Mountains-to-Metal steel front door pockets with molle bags
Nice build @JRBinMalibuCanyon first thing I thought of was an old render I had downloaded from this forum back in Aug of 2020. ;)
Ford Bronco Custom 2-Door Wildtrak “Heritage Edition” Bronco Build B49CF34E-256F-462F-ACCE-F1DA7580A0B1
stickshifthappy
RVA
I see so many members with a much better eye for design, fit, and details then the current Ford team. Makes you wonder. 🤔
Absolutely nailed it! Well done!
The Ford designers aren't the rabid Bronco enthusiasts that Bronco enthusiasts are. They have accountants, engineers, production managers, deadlines, design by committee, supply issues, and a host of other issues that drive vehicles to a more homogenized product that will appeal to a mass audience.
TopRecon
2021 2D Basesquatch
In all fairness they're actually offering this from the factory next year.
Burnz442
PJ
1930 Model A,1969 442 W-30, 1986 CJ-7 2000 Firehwk
Better than Ford! Probably cheaper as well LOL
NJRoadkill
South Jersey
www.instagram.com
22 Bronco Badlands 2.3l Manual
It’s a lazy execution by Ford in comparison. IMO
There are renderings by forum members/enthusiasts of some variation of this build well before the Nintendo images. I have no doubt they look to the community for trends and demand. Much like Harley Davidson does.
OP build blows that out of the water. although I like the square quarters and flares.
DC9atnight
Toyota Tacoma
You made so many better decisions than Ford did on it’s Heritage Edition that it’s not even close. I would take yours hands down. Just a great job!
