I thought some of you may enjoy seeing some pics of mods/accessories. I collected all pieces to this puzzle over two months or so, then did it all in one wave. If you live in the 4-corners area (SW Colorado, SE Utah, NW New Mexico, Northern Arizona) you may want to consider working with Chris (owner) of AudioBox in Cortez, CO.
My ride is a Black Diamond, 2.7, mid pkg, MIC, tow, roof rails, factory PPF. I added PPF on both sides about 50% up after delivery, and the front bug deflector Aeroskin II appears to also help with deflecting rocks from the windshield.
Although he specializes in audio related mods/upgrades, he also has all two way radio experience you could ask for, and did all electrical connections for me. 3 of us worked together for 8 hours straight and got the entire list completed. I did this in order to avoid pulling trim panels multiple times, this way everything was done together and by participating I know where and how everything went. They did a super job and I a m very pleased with how it all turned out.
I don't want to post all details of the various parts, so if you have a specific question, let me know.
Here is a list;
- GMRS Radio Wouxun KG1000G
- Ditch Lights with brackets, integrated with GMRS Antenna
- Diode Dynamic Fog/Driving Lights, the 6" S6 light bar
- two LED cargo lights (because the standard lighting is inadequate at night, when you need it most)
- Garmin Overlander off-road GPS with integrated BC35 front facing camera (for on-trail wheel placement)
- replaced all four 4" speakers with Alpine, and added sound deadening mats inside the speaker cavity
- Vantrue front and rear-facing dash cams with loop recording, parking mode, GPS, g-sensors
- Archetype BYOD rail on the dash with phone mounts
- 1UP Hitch swing-arm Rackattach with 1 UP bike rack
- license plate relocation bracket
- GPCA grab handles for back seats
I was especially pleased with how the GMRS radio was mounted, the unit is under the dash driver side, and the face-plate overhead driver side. Chris did his magic with pulling those wires through some pretty tight spots, but having experience and the proper tools/tricks made it possible. Equally cool was using the ditch light mounting bracket to also carry the GMRS antenna, this worked really well also and is rock solid.
Changing out the speakers was quick and easy, and for sure, 100% worth it. Makes a huge difference and only cost like $30/speaker, plus wiring harness and sound mats.
I also love my Garmin Overlander with front facing camera. I did not want to spend all the extra to get the high/lux options, and I did not want connection dependent navigation, so this alternative saved bucks and works just fine. Chris mounted the camera in the exact same spot as the factory installed one by fabricating an appropriate bracket and it connects wireless with the Garmin display. I press the "rear view" button to get the front view while on trail for wheel placement.
The Diode S6 front fog/driving lights are wonderful, make a big difference and I use them daytime as DRL in addition to the factory whites. They have a distinct cutoff line which I placed below the headlights main beam, so no blinding of oncoming traffic.
The ditch lights are like two suns and will serve great during off-roading and/or camping.
If you need help or want a pro to install your electronics, you can reach Chris at 970-565-4019 . I have no gain or interest in referrals, but am sharing his contact info because it really made the electronic installations a good experience and I can recommend him 100%.
Mods remaining and yet to be done are the Yakima roof platform, and Method 305 NV Bronze with 285/70/17 BFG K02s
Here is a list;
