Dashboard USB Ports on Non-Lux Bronco
Julz670
Julz670
Julian
Minnesota
www.youtube.com
Previously: '83 and '95 Bronco XLTs. RIP.
Looks like I'm buying a universal marine usb socket and a dremel.
F the micro USB port, gimmie at least two of them big boys!
Agreed, I don't use Apple products so I don't have much need for the little one, I need real USB port. At least for now, until all the other electronics companies switch over to the type C.
I just don't have much confidence in making it look nice if I have to cut my own hole in the dash. Maybe its easy, I've just never tried anything like that.
Apples
Nick
2022 Jeep JLUR, 2004 Lexus GX470
_finack
Fort Lauderdale, FL
2015 Lincoln MKZ
It's USB-C, not micro USB.
It's for future-proofing (as much as is possible with tech these days). While USB-A is still by far the most common, USB-C is becoming more and more common.
BrentC
Brent
Calgary, AB
Having modded the dash somewhat on my Focus ST, I would suggest you pop the tray out and install your USB ports in it. In the ST there was a USB port on the radio in the dash so I just extended this port to the dash top instrument cluster. I mounted it beside my shift light indicator. Easy peasy.
_finack
Fort Lauderdale, FL
2015 Lincoln MKZ
It's not just Apple that uses USB-C. My Google Pixel 3a, Sony wireless earbuds, and a LED video light all use a USB-C connector.
By the way, the panel by the phone charger has both types as well.
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
Rick Astley
Up Doug's ass
d
FWIW, Ranger has no USB power provisions there. Ranger5g members have spent the entire $20 to get the USB setup from Raptor and install it. Push clips are pretty tricky, you'll also need a flat head screwdriver or plastic wedge.
If USB ports are why you "need" to buy the Lux package, those are some miiiiiiiiiighty expensive $20 parts you're after.
Will let you search their forum for the part numbers and trim needed. Ends up looking quite tidy, I know it works great in our Ranger.
Rick Astley
Up Doug's ass
d
I wonder how easy it will be to remove that piece. The plastic trim panel that is under discussion.
If it can be popped off without more dash removal, then wires should be easy to find and something like this could be installed.
Read my post above. Ranger 5g has the answer you're looking for.
Julz670
Julz670
Julian
Minnesota
www.youtube.com
True, many other companies are switching and soon all will (should) use type C, it is definitely better. My Lenovo laptop even uses type C to plug into a dock that handles all USB type A devices, ethernet, and HDMI. Definitely a more universal plug than the USBs of the past.
Espy
2023 Ranger XLT Tremor
In my 2007 F150, I had a truck accessory shop mount a Garmin GPS above the rear view mirror and run the wire inside the A-Pillar, add usb power both below and in the dash. Paid about $225 for the work and it looked great. I'd recommend something similar if you want USB in the dash.
_finack
Fort Lauderdale, FL
2015 Lincoln MKZ
There’s this:
Ford Bronco Dashboard USB Ports on Non-Lux Bronco PXL_20210406_211628529
Not sure if this is production.
I don't understand what the sides of that rail attach to. There were no attachment points or slots for the sides of the rail in with Bronco I saw yesterday.
Julz670
Julz670
Julian
Minnesota
www.youtube.com
Agreed, if the power ports are the only reason someone wants Lux, not worth the price when it can be done aftermarket for pretty cheap. I had planned on buying my own power ports and adding them, was just concerned about DIY because I want it to look nice and have never drilled into my dash before. I might still give it a go, working careful and precise, I should still be able to get it to look nice without going to a professional.
Julz670
Julz670
Julian
Minnesota
www.youtube.com
I assumed that the middle part of the rail is just SLIGHTLY lower than the sides, providing enough pressure to hold the sides down when the middle is screwed in. But on a real bumpy trail it might be annoying if you have a heavier device attached toward the end of the rail, may still bounce a lot.
_finack
Fort Lauderdale, FL
2015 Lincoln MKZ
USB ports USB schmorts. I'm getting lux for the garage door opener!
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Ford Bronco Dashboard USB Ports on Non-Lux Bronco PXL_20210406_211518455
They don’t attach to anything. There’s just little feet that support the weight. I imagine the lips on the dash also help to prevent the rail from rotating around the center attachment point.
The rail in this thread is the 4wp part. Previously we had seen two different length prototypes. One like this, and one that comes to the ridge halfway out. Same little foot design.
