Felix808
SRV CA
One peice at a time, bought my warthog online, I'll have the only one there is around!
I use to say I was building my new truck one part at a time when I had my XJ :p
gentlemanbronco
Rick
ford fiesta 5.0
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
I can’t find the thread but I remember it was determined this swap is not compatible. Yikes, I hope for your sake it works out. Keep us posted as I’d like to have a definitive answer to this. Good luck!
Rusty Sheckelford
Rusty
LA
Just make sure you finish it before the next refresh, or you'll end up with a '20, '21, '22, '23,' 24, '25, '26, '27, '28, '29 Broncomobile
Rick Astley
Up Doug's ass
d
So I bought a Big Bend Bronco because mine wasn't going to get built anytime soon. One of the things I liked was the Signature LED headlights and mine didn't come with them. Low and behold I found a pair, or what I thought was a pair on eBay. When they arrived today, I noticed something interesting. One of the lights has the name WARTHOG and the part number on it. Did I somehow get a preproduction WARTHOG/RAPTOR headlight? I guess I'll found out when I plug it in. If it's a no go as far as both being the same, back to eBay.
I'm very interested to see if you can get this to function. This was very, very, very price and process prohibitive for Ranger.
I made a thread on this very subject a while back (that you obviously didn't find through using the search function prior to pulling the trigger on buying lamps) and it's exceedingly unlikely you can get them running if Ford followed the Ranger playbook on the upgraded lighting.
https://www.bronco6g.com/forum/thre...rom-base-to-signature-possible-process.12196/
That being said, I would love to be wrong on this! Look forward to your findings and updating the thread above with your results.
UpstateNYFordGuy
Peter
Upstate NY
2021 Ford Bronco Big Bend - Cactus Gray
It was my bad for getting so excited to think there was a possibility it may have worked. It's not like the old days, lol. After talking to one of the techs at my local dealer, he checked into 2 mannequins (1 with signature lighting and 1 without, both Big Bends) they have on the lot and he is pretty certain the base version doesn't have the required components to make the Signature headlights function properly. The taillights are certain to not work due to the BLIS components the lower end trim doesn't have as described in your post. I hope the aftermarket catches up soon and I can seek out other options. I just want mine to be different from the sea of Big Bends that will be roaming the roads soon.
Rick Astley
Up Doug's ass
d
Hey, they will work for sure. It just won't be plug and play!
Search Ranger5G for threads. There's a guy there that documented the process as he runs full LED setup on a base Ranger.
(Helps he works at a dealership)
friethmiller
Everglades
Fred
Austin, TX
2013 F-150, 1974 Porsche 914, 1974 Porsche 914 LE
Everglades
Knowing me, I'd try pulling them both apart and attempt to merge the two lamps together to create a "Franken-lamp". It would probably work.... till the first time it got wet.
Villagevip
James
The Villages, fl.
"68" "72" Broncos, sadly sold, back in the day
Also not plug and play, plastic front bumper to steel modular ... FYI, Have to sawzall, front tow rings off on plastic bumper trims to fit......
edgeflyer
2013 FX4
Corporate logic says that once the Warthog name was canned, the brains of the operation made them sell anything with a Warthog sticker and the built new parts for the Bronco Raptors with proper stickers.
BroncoNapped
Bert
2000 S10
Yeah, it should work... at least electrical wise. I've seen them on hotrod and classics. I m going to upgrade to led on my 52' pickup.
As far as plug and play....
You may need to change the plug or cut both plugs off and wire together
