Didn't switch out of 4A from Sport Mode
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Ok tried it at lunch works the same. Shut off in sport when I went to leave you get the pop up to return to sport mode I declined and it stays in 4a. So it is programmed that way and not anything you did with forscan.
‘21OBX
Ken
90Bronco19
I figure why run the 4wd components when not needed? And likely makes worse mileage?
The Bronco does not have disconnecting hubs like the F150/F250. So your turning the 4wd components anyway ( unless you have a non advanced transfer case. The there is a disconnect on the front axle but it still does not disengage the cv axles from the hubs). All the 4A magic is in the transfer case having clutches and at the ready if the system sees rear wheel slip.
dimasin
Dimasin
FL
Ford Bronco
My Black Diamond with SAS and manual transmission did exactly same thing yesterday. It has Sport Mode. I turned it on and then turned back to Normal while idling at the intersection. Does it have to be with parking brake engaged in order to shift back into 2HI?
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
No...I have MT also and have never used parking brake when switching 4wd modes. Nothing really "shifts" when it goes from 4A to 2H(even tho the dash says so)
taperunner
Chicago
None
Thanks for testing on a rig that didn’t use forscan! I didn’t really think it would be an issue I was just curious if it was a forscan gremlin.
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
2021 AMB Bronco, 2021 CO Bronco
Mine stays in 4A after using slippery the day prior. I have not used Forscan.
CeeCeeBronco
CeeCee
Houston
I have sport mode from the factory OBX. It automatically goes to 4A that’s just how it’s setup. Now I haven’t shut it off i. Sport mode to see if it stays in 4A.
I dislike sport mode it’s too jumpy For my in town commute. Sounds like I’m driving a stick and forgot how to shift lol.
On that note I sure wish ford would push an update so that it stays in the mode you left it in.
If I remember I’ll try it on the way home and see if it stays when I restart.
It does stay in the mode, somewhat. It will prompt you to ask if you want to stay in "blank" mode at startup.
mpeugeot
Right, but I'm saying that after using sport mode in 4A, I parked the car for the night. This morning I got it and if defaulted back to Normal but stayed in 4A. I believe Normal should use 2H
That's normal behavior. My OBX always has been this way, even before FORSCAN.
mpeugeot
BTW, the way the 4A transfer case works is that the computer adjusts the clutch pack to be right on the edge of engagement, then will adjust the clutch pack as needed to the conditions up to 50 Hz.
Techun
Pa
BD, 2.7, MIC, 4dr
I don't think they're allowed to do that. It has to default into the epa-tested mode.
‘21OBX
Ken
90Bronco19
Most of the time it’s eco mode in leave it in🤣. I Jesus that I have seconds to say ok. I’m putting my belt on putting coffee in the cup holders. There has got to be a forscan code for this like with the headlights you can have it remember where you put them or reset every ignition cycle.
JohnnyBronco
Pennsylania
X4
Okay ok thread but
Staying in 4A is normal. Defaulting to Normal is also normal. These are factory settings and even unlocking the options with forscan still utilizes default settings. If you were in 4A when ypu shut off vehicle you will be in 4A next time you start. If in Sport when you dhug off you will be in normal when you restart although over short periods of time it should ask if you want to return to Sport so hit the OK button
helifino16
Ron
Mount Sinai, NY (Long Island)
Mine does the same thing. I’d call it a bug but not enough to complain to Ford about, particularly as we used Forscan to enable it.
My Wildtrak does this also - and it came with Sport Mode. When I switch on (or press 'OK' to keep in) Sport mode (at startup), it always switches back to '4A' (if not already there), but like suggested, I just press '2H' or just leave it in '4A'.
I really like how Sport Mode wakes up the 2.7, just feels WAY better.
