- Adam
- Aug 30, 2021
- 341
- 4,286
- 5,730
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
The new Diode Dynamics SS5 Kits were very popular at this years SEMA show. Unless you live under a rock, you saw their new SS5 installed on a few Broncos at the show. We're happy to announce that we're taking pre-orders on these kits. We're one of the largest stocking Diode Dynamics dealers so rest assured you're in good hands with your purchase. These kits are expected to be arriving January 21, 2022 so we're be taking pre-orders right now
We recommend getting your orders in ASAP to secure your spot in line and be one of the first to get these on your new Bronco!
The biggest feature (we feel) on the SS5 is the selectable backlight color. With eight color options it's easy to select the color you want.
SS5 Grille CrossLink Lightbar Kit for 2021 Ford Bronco
https://www.4x4truckleds.com/diode-dynamics-ss5-grille-crosslink-lightbar-kit-for-2021-ford-bronco/
Sport Level: $1,399.95
Pro Level: $2,099.95
Available in White or Yellow
Features
Perfect Fitment. The Grille CrossLink Lightbar Kit for the 2021 Ford Bronco from Diode Dynamics allows you to mount six linked SS5 LED pods in front of the factory grille. These application-specific brackets were CAD-designed to bolt into place using factory mounting points on the factory grille. No cutting or drilling required!
Designed for Performance. Featuring the highest output intensity of any 5-inch LED pod on the market, these auxiliary lamps have been designed for maximum functionality, with patented technology and custom-engineered TIR optics, all in a durable package.
Selectable Backlight. The Stage Series 5" LED Pods included in the White kit feature a selectable backlight with eight different color options, perfect for an extra styling accent, or for more visibility when you’re not using the main beam. Selecting your backlight color is easy - simply alternate the power on and off. There’s no complicated programming with a controller! The SS5's backlight fully illuminates the TIR optic, providing unique accent lighting that you won't find on other LED pods. NOTE: Due to the yellow lens, the Yellow kit is only available with an Amber backlight color.
CrossLink. Our patent-pending CrossLink technology allows you to link up to eight SS5 pods together to create your own lightbar. Unlike other options on the market that use multiple pieces to link pods together, we have designed a single-piece CNC aluminum link. This provides extreme rigidity, but is fully adjustable, for both straight and curved configurations. And thanks to inset threaded mounts built-in to every SS5, there is no need to buy a special linking version of the SS5 for your setup.
Control through OEM Aux Switches. Included with the kit is our OEM Auxiliary Switch Wiring Harness. This harness allows you to control your lights using the factory-installed aux switch bank. Two switches will be used - one for the main beam, and one for the backlight. For those who don't have the aux switch bank, our Heavy Duty Wiring Harness is also included to mount a switch and connect directly to the battery.
SS5 Windshield CrossLink Lightbar Kit for 2021 Ford Bronco
https://www.4x4truckleds.com/diode-...-crosslink-lightbar-kit-for-2021-ford-bronco/
Sport Level: $1,699.95
Pro Level: $2,599.95
Features
Perfect Fitment. The Windshield CrossLink Lightbar Kit for the 2021 Ford Bronco from Diode Dynamics allows you to mount seven linked SS5 LED pods above the factory windshield. These application-specific brackets were CAD-designed to bolt into place using factory mounting points above the factory windshield. No cutting or drilling required!
Functional Output. Stage Series beam pattern options were designed with advanced optical simulation modeling, to shape the output in highly-functional beam patterns with high efficiency.
Check out this video from Diode Dynamics for an overview on the new SS5 LED Lights
Features
- Bolt-on fitment on 2021 Ford Bronco
- Ultra-high intensity, with custom-engineered TIR optics
- Selectable backlight color, with eight color options
- Torture-tested, heavy-duty construction
- Control through factory aux switch bank using the included harness
- Assembled in USA
Features
- Assembled in USA
