Ditch the towing package for now and get one from Ford or aftermarket later to avoid any delays?
peta8368
Norwalk, CA
2016 Polaris Slingshot
Ford needs to delay all tow package to MY22, but make wiring standard for all builds. Do it like the hardtop fiasco. Simplifies build, and removes constraint. Win win!
(half serious...)
Peter
Bikeric
Tulsa
1984 4Runner (For Sale)
I'm in the camp of not having the factory tow package because it's just not worth $600. Also, the Bronco tow rating is only 3,500 lbs.... Most States only require trailer brakes above 3,000 lbs, so it's barely in the realm of needing a brake controller.
Lorenzo
Larry
Oakland, CA
Ford F150
I like the confidence of a factory unit for this type of thing
Headsong
There will be after market options if you want to do a basket without a receiver hitch...these are for jeeps, but Iā€™m sure someone will come up with one for Broncos
How the hell am I supposed to get the deer up there? Oh, with the Bobcat on the trailer....
HBTFD
Newnan GA
F350
All the discussions around adding a brake controller are based on people looking to "adjust" that 3500lb rating.
(through different hitches, upgraded springs... etc etc etc... )
Donā€™t tell the insu
I'm under the impression that the bolt on hitch is being installed before the bumper (and a lot of other things). Hence the possible the need to cut or remove the bumper to install an aftermarket option.
It appears if the nut plates are on the rear side vs front the bolts can be assembled without removing the bumper.
Ford Bronco Ditch the towing package for now and get one from Ford or aftermarket later to avoid any delays? D049DC23-08A6-44C8-88AF-4023A56312A9
donspillman
donspillman
Don
Baton Rouge, Louisiana
2013 F-150 4X4
My dealer said that they have not been told the towing package will be late availability, and that most of his orders contain that option. So, I decided to keep it.....for now....
donspillman
donspillman
Don
2013 F-150 4X4
Trailer tow was on the list of commodities I was given. Now how big of a commodity depends on how many want it. Based on my orders, I think the mass majority 75% or more, but that might just be regional and if so national rate could be lower where its a commodity, but not a major one.
What I mean is:
Say Ford can build 50% of Broncos with a widget, so the commodity rate is 50%. If demand is 50.5%, its an issue that will slow up some so it is a commodity, but only will affect 1 out of 100 orders. Now lets say demand is 70%, now its 20 out of 100, so its much more of an issue. Then remember that the next week, those 20 allocations take the first 20 widgets leaving only 30 for the next batch so the wait/line keeps growing.
So back to trailer tow, if you think its 1/2 or less of the orders, probably won't be a huge deal, if you think its 75% or more, might be a big problem. However, this also assumes the commodity list I saw was correct, and that it won't change. Trailer tow is one I can see easily increased if demand warrants unlike other options like 2.7L, Sasquatch, etc. Clear as mud?
Also remember once scheduling starts, dealer will have a long (2-3 week) preview period where you can change the orders if its not going, so if Tow is a problem keeping your order from scheduling, dealer can notify you and see if you want to drop tow to get a VIN.
Thank you! That clears it up for me. You are super helpful for this forum.
2Jeeps&PatriotX1
Denver, CO
'23 4dr Badsquatch, ā€˜05 LJ & ā€˜17 F150
$48,000?!?! for a popup?
Anybody want to start a pop-up camper business with me?
It's a bit more than just a pop up camper lol. And you'd be surprised how the cost add up when you start adding everything up. I looked at a lot of campers and the fit, finish, quality and creative use of space made the decision for me.
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
I think I have found were some of the cost of the Trailer Towing packages comes from. Looks like Ford is using variable voltage tail lights, which means one bulb for brake and parking. There is added wiring and a Trailer Towing Module that is added. Don't know how much is there if you do not order the towing package.
Ford Bronco Ditch the towing package for now and get one from Ford or aftermarket later to avoid any delays? 2
Ford Bronco Ditch the towing package for now and get one from Ford or aftermarket later to avoid any delays? 1
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
Well, I thought had read on this forum that it had been added as possible delayed or high demand availability. (I'm pretty sure I did, I remember everyone fussing about how hard it could be to add the towing package.) However, I can't find it here anymore. I'm I just making this up? Can a Dealership person on here or anyone else confirm this? Thanks.
Iā€™d be more worried about chip availability than towing package.
G Watkins
2015 Jeep Cherokee, 2019 Dodge Challenger
Can someone explain what would customarily come with a towing package? Iā€™ve never had one. Never needed it. But I wonder about future proofing this ride - what would I need to add and what would it cost if five years later I want to drag a small teardrop trailer around with me?
I think you can add a tow hitch and brake controller for less than $500. You can get just a tow hitch from Uhaul for around $250.
dgorsett
colorado
F250, Mustang, Explorer
Looking at the bare chassis in Moab you are correct. The bolts come in from the bumper side. Meaning at least the plastic bumper facia would have to be removed to install bolts. The after market ones for jeeps (which are very similar if not identical to what the Bronco would need) the bolts enter from the chassis side. On the Bronco this might require loosening the muffler to get access.
bronco49
Ed
california
1964 Lincoln Continental
I was told besides the hitch and the wiring there is a computer adjustment to the engine and a bigger radiator. Can anyone confirm this?
