GroovyGeek
Boyan
'23 Bronco BD
Two things missing from the vid - Ronin plug and recommendation to tilt the rig slightly to the passenger side - that helps get the last piece of oil out of the system. The Ronin plug saves you from making a mess when pulling the OEM plug.
timhood
Tim
Several
You can't buy 6 quarts of decent full synthetic anywhere for $33 (retail) let alone with an oil filter, replacement drain pan plug. Sounds like a great deal!
Yeah, it's a loss leader for the dealership, but they make tons of money on the extra service they get on other owners. The multi-point inspection is all about finding other work for them to recommend. 🙂
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRDORP, 2023 4Runner TRDORP
Good write up. Just make sure you put 7quarts for 2.7.
Why 7 quarts my owners manual says 6 quarts?
Getting ready to do my 1st oil change at 1500 miles this week, have Motorcraft oil filter/oil and a new Yellow plug from Amazon. Bought enough to do 2 oil changes and it was $100 all on Amazon so about $50 per change. I change all my own oil so have to run to Orielly's a few times a year to dump my 2 5 gallon jugs of used oil. Been dumping there for 20 years so I just walk in right past the counter to the back dump and leave, no hassle at all.
RustysBronco
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
The OG Bronco Forum Users Doing Their Oil Changes:
CMillBronco
Craig
Johnkn
Maryland
'66 GT350, 68.5 CJ Mustang, B2, Viper, Pantera,TRX
UPR Billet valve.....
Ford Bronco DIY 2.7L Engine Oil Change - Save $$ and Learn Your Pony! 🐎 XJrdvG
RustysBronco
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
I've been putting 7q in my 2021 since 11/18/2021. Ill meet in the middle 6.6 LOL.
It's like you're dreaming about gorgazola when it's clearly brie time! (See video above) 🤣
FstFrd00
www.gunsmithingtx.com
2021 BD Sasquatch
I went to a quick lube place while in college ( ~20 years ago), they stripped my oil pan and somehow broke a tool off in it. They denied responsibility until they were blue in the face. That was my first and last time not DIYing an oil change.
prospectfour
Pete
NJ
'22 Bronco, '18 Tiguan
nice video but a quick word of caution for the diy community (of which I am one). i have another Ford where I ran into an extended warranty issue because I could not locate the oil change receipt,with indicated mileage, for my very first oil change. 2013 Ford flex with a stretched timing chain At 105k miles, and an aftermarket extended warranty to 120k miles. the issue nearly cost me over $4k. The warranty company finally agreed to honor the warranty only after inspecting the engine for build-up after the front end was removed. The entire hassle was over one single missing oil change receipt, with mileage record. I take my 2022 wildtrak to an oil change place where they maintain records. If you are doing your own oil changes, be sure to keep solid records and devise a way to record the mileage when you do your changes.
I typically pay for maintenance through the warranty for this reason. Once you're out on your own there's no incentive to be making dealer donations.
timhood
Tim
Several
